LPG (1 Viewer)
Sep 28, 2017
87
24
Audenshaw Manchester
Compass 180 Rambler
2017 Just started as Retirement looms in August
I want to change the Calor Bottles to LPG
Wheres the best place to Purchase them,I have had a quote from Autogas 2000 its in the region of £600
with all the extras,
I will be fitting it myself
Thanks in anticipation
Allen
Lenny HB
52,684
147,591
On the coast in West Sussex
Hymer B678 DL
I assume that is the price for Alugas bottles they are about £150 dearer than steel bottles, they can supply Gaslow steel bottle and there are other suppliers like Gas-it who's steel bottles are cheaper.
A
Sep 28, 2017
87
24
Compass 180 Rambler
I've Just checked Gasit web site and yes they are considerably cheaper,
Thanks All
Reactions: JFD
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
I think autogas2000 supply gasit bottles. Worth speaking to them.
Sep 1, 2007
53
22
Guildford
Van Conversion
since 2004
I have a underslung system supplied by Autogas 2000 and fitted by Dave Newell works brilliantly especially with the cut off valve and of course gives me extra room in the locker
cantonalegod
140
80
Devon
Rapido 8086df
2 x 11kg gasit bottles fitted with white external filler at gasit Bristol a few weeks ago £400 all in!
Jan 31, 2016
1,891
3,342
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
None on mine, a photo would help.
I realise now its the Multivalve cylinder, which is new to me.
JFD
Apr 9, 2015
392
238
Crawley Down, West Sussex, UK
Pilote Aventura G730
since 2014!
Having struggled with replacement cylinders, we went the Gasit way last year, single bottle with a small propane bottle as backup. This year we binned the propane bottle for a second Gasit one. Self installed, which was easy. Only heart-in-mouth action is drilling for the external filler! No issues so far, apart from a finding a seemingly autogas-free area in Austria this summer!! Finally found an industrial estate with a self serve dispenser just in time!!
Only real question is, why didn't we do it years ago???
Minxy
32,488
66,008
E Yorks
Carthago Compactline
Easy to fit yourself and Gas-it cylinders are generally cheaper but shop around as you can mix and match the other bits such as the pipes, filler etc to get the exact combination you want, as well as the fill point adaptors. We used to have the large round Gaslow filler on a bracket in the gas locker but I changed it this year for a much smaller external square one which I put in the corner of our camper's rear bumper, the adaptors simply screw into it as required and being smaller it's a much simpler filler to install.
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
The Alugas are considerably lighter and the ‘tops’ come off making them smaller and more likely to be able to fit a larger capacity (not sure if this is the case with other systems)
Reactions: f6c
May 7, 2016
7,187
11,609
West Sussex
Since 2003
Agreed. Also less stressful than making a hole in the side you can wave through. I felt the smaller filler would be more secure too, having four drilled bolts rather than a notch and clamp to keep it in place.
Tincataylor
639
1,360
Devon
Never leave a campsite with your clothes line tied to a lamp post.
Another vote for Gas-It. The service on the phone was excellent and all the gear to fit a 11Kg cylinder and filler point arrived on time. Fitting could be carried out by anyone with reasonable DIY skills and the overall cost was way cheaper than Gas-Low. Other than the colour the cylinders are identical as far as I can see and we have found re-fillable to be much easier (and cheaper) to live with than calor cylinders.
The Tincas
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
While we’ve not had the problem others have reported that you can be refused to re fill bottles at certain locations, so from this point of view an external filler cap gives the appearance of the vehicle being LPG powered
Lenny HB
52,684
147,591
Hymer B678 DL
So it just replaces the handwheel, our cylinders are 2014 transferred them from the last van.
We had a woman run out to us in Portugal shouting "we don't fill" bottles" I pointed at the filler and said "it's a tank" she said "OK".
Always used the small filler and always fitted in the sill, no way would I want a filler in the bodywork, especially with the weight of those filler hoses.
PEM
Jun 5, 2011
65
110
Lancashire
coach built
Fitted the 18Kg gas it 4 hole bottle earlier this year was a doddle to install and have not had any problems so far touch wood, would recommend gas it
stephen78
43
63
swansea
Pvc
since 2014
Attended a gas course at the Gas-it premises earlier in the year the course was taken by the director Nick a very knowledgable fella , they have an impressive setup there, they carry a lot of stock and develop and design a lot of the products they sell including the gas bottles and tanks , very professional company a pleasure to do business with.
PeteH
6,853
9,029
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
What`s the "cost/Benefit" of a Retrofit?. All my R-V`s arrived so fitted anyway. I can see it in Europe, where convenience would be the big advantage, and LPG is generally cheaper (well it was in Spain). But in the UK I would suspect that you would have to be (almost) a full timer to use enough gas to (re)cover the Outlay?.
Jul 5, 2013
11,713
13,681
Since 2013
I am not a full-timer and have been using refillables for about 3 years now and I reckon I have saved most of what they cost. But it is the convenience wherever you are that really is the selling point. No undoing gas fittings and manhandling heavy bottles to the local Calor dealer and back. Just fill it like you do with diesel. After all we don't hump cans of that about do we, so wjy should we with LPG.
stephen78
43
63
swansea
Pvc
since 2014
I am not a full-timer and have been using refillables for about 3 years now and I reckon I have saved most of what they cost. But it is the convenience wherever you are that really is the selling point. No undoing gas fittings and manhandling heavy bottles to the local Calor dealer and back. Just fill it like you do with diesel. After all we don't hump cans of that about do we, so wjy should we with LPG.[/QU
Also in smaller vans an under vehicle tank will free up vital locker space for more storage.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Albeit that it was expensive, it's the convenience factor. Had ours fitted about 6 years ago. Instead of buying 2 Calor/BP cylinders at around £50.00 for 2/3 weeks (and lose some because not totally used), I now don't have to disconnect, go to the local suppliers, wait in the queue, the fuel used to go to the supplier and back and the time involved.
When in France/Italy/Switzerland for 6 weeks, we'd have had to buy alternative cylinders, so I definitely reckon my system is paid for plus I still have the convenience of my Gaslow system (other makes are available)
