LPG Tank (1 Viewer)
Dancers
40
40
Preston
Carthago Malibu
6 years
Hi R.V.ers
Can anyone advise us newbies on how to go about filling our LPG tank? Can we just go to any filling station? What do we turn on/off? How does the filler pump attach?
Any info gratefully received. Also do we need some kind of safety certificate for it and if so, where would we acquire it?
Thanks.
TheBig1
17,611
43,139
Hi @Dancer you can refill at a suitably equipped and sized petrol station with lpg pump. then you need an adaptor to fit your rv tank, attach hose from pump and lock on then press and hold the red button on the pump and hold in to dispense lpg
Pete5996
767
1,868
Deep in the Lot
Autotrail Cheyenne
Since 2002
There are a number of vidoes on Youtube such as this one, which will give you a good idea as to what's involved:
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
Here is link to using an adapter, we've not filled up yet at all, so are looking at this with a little trepidation. Bets 'bottled it ' (unitended pun.. honest) in Luxembourg because it said on the pump no bottle refills!
Nov 24, 2008
867
2,168
Anywhere that takes our fancy
Since july 2009 And Still Going Strong
Defiantly worth watching several videos as theres a bit of a knack depending where your filler point is on the van. The locker mines in is small and the nozzles with big protection collars are difficult to connect up. See if theres a funster nearby that could come and advise. some parts of the country have very few log stations and some you may find it impossible to get to depending on the size of your van. Hers a link to a site I use for searching out stations www.mylpg.eu/stations/united-kingdom/
Im sure you could find someone to do a safety check but theres no need as far as I'm aware.
If you've an RV have you had a look at our sister site which could be of additional information regarding everything RV.
www.rvoc.co.uk/forum/
Enjoy
Shawn
Mar 23, 2012
9,541
32,043
sleights
c class
Hi there Dancer
Just drive down to Preston Gas Centre in Penwortham.
https://www.google.co.uk/maps/dir/'...7a5745b29405f55!2m2!1d-2.7057525!2d53.7420482
They are really helpful and will actually do it for you. The best way to learn.
I always use them.
That sounds a really good idea I had a polish bloke who filled his car before me help me the first time. I wear welders gauntlets to fill mine for safety just keep them in the gas locker might be a good idea. Filled in France for the first time this year their design of filler looks a lot better than ours I find the bayonet thing tends to get stuck.
Dancers
Dancers
40
40
Preston
Carthago Malibu
6 years
Thanks everyone for your help. We have our Damon Daybreak booked into Lancs County Highways for our MOT near end of M65 at Preston at £57. Now searching for somewhere to have service on ford/workhorse and habitation service. :)
icantremember
8,331
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I'm pretty sure I have found lpg pumps with red, green and black start buttons ... be aware the pump will probably display the previous customer's purchase until you press this button when it will reset to zero before the gas flows.
The above video shows a woman filling with bare hands ... the nozzle gets extremely cold during filling and there is a small amount of gas released as the nozzle is removed both of which can cause freeze burns to exposed skin .. I would certainly recommend the use of good leather gloves.
ianandkath
897
1,519
spain/uk
a class
2 years
millers at longton, or standish service station. both are good and i have mine moted at standish.
i use preston gas, cheapest near me, but also used morrison at leyland.
BMM
205
176
Essex
I'm a Newbie
Always turn off your fridge before filling up if it's running on gas
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
Did our first fill today ......... no problem at all...... only thing was while I was prepared for a blow back removing the hose, I didn't realise it would happen when the bottles were full, and I was no where near it.
Rough estimate looks like a litre per day ?
