- Dec 14, 2020
- 17
- 15
- dont own one yet
- planning a conversion
Wear gloves and safety glasses when filling up
with gas.
As Grumps pointed out, it will make a real mess of your skin. Imagine what it will do to your eyes.
Take your time and you will be fine
I always wear heavy gloves, liquid LPG vapourising point is - 42Ā°C it can give you very nasy burns. A Funster ended up in hospital a couple of years ago with LPG burns.
Never seen that happen in several hundred fill ups of car tanks and Moho cyls but now I need to assuage my curiosity so I'll try next fillDon't let go of the button when filling as it resets the pump. You will have to go and pay for what you have put in and start again.
Agree what you say Lenny HB but I bet you don't fud about disconnecting filler as per above video.. sure you like me and release pressure and stand backI always wear heavy gloves, liquid LPG vapourising point is - 42Ā°C it can give you very nasy burns. A Funster ended up in hospital a couple of years ago with LPG burns.
Some pumps are like that, others OK to stop and start. You only find out when it's too late.Never seen that happen in several hundred fill ups of car tanks and Moho cyls but now I need to assuage my curiosity so I'll try next fill
mintravels As I was informed when I was a newbie and asked the same question I was toldI have a bunch of silly little questionstr
thanks for this. i really appreciate it. i might print this on a little card and laminate it to keep in my pocketInstructions are displayed on the pump. It is a bit disconcerting when you do a fill for the first couple of times.
Effectively sequence is to
remove any filler cap on the vehicle
get filler nozzle from pump (last time I did that I spend a minute just trying to get the nozzle to release from the pump housing - weird)
Engage nozzle to filler valve. Usually need to align a couple of slots, lightly push nozzle home and then a quarter turn of the nozzle housing to engage.
Remove hands from anywhere near the nozzle, usually to the handle and behind.
Engage trigger on the nozzle handle (the garage I frequent signage implies the trigger will hold in place, but I have to retain a hand on the trigger.
Now depress, and hold depressed the pump button - often a large big thing.
Keep depressed. May be a very, very long pause for something to happen. You may be waiting for the attendant to authorise the pump. Eventually the pump display will start doing something and a very slight noise implies gas transfer.
As the tank becomes full rate of transfer will slow, then stop on the pump display. Only now do you release the pump button.
Now release the nozzle trigger. Don't put hands in front of the pump handle until trigger is released.
Now disengage the nozzle. Reverse turn the nozzle. There will be a sharp escape of gas, often with slight "bang", brief vapour cloud and a short smell (no smoking!)
Return nozzle to the pump housing
Refit your filler cap.
Get out your plastic at the cashier
Drive away to your next campsite.
Yup!Instructions are displayed on the pump. It is a bit disconcerting when you do a fill for the first couple of times.
I think that I will carry on wearing my gloves then for the LPG fill !I use gauntlets to do this as normally in t-shirt - same gauntlets used for emptying toilet. You have been warned.
