The OP was quite correct when he said he expected to get 22/24 ltrs in.... 80% of 30ltrs = 24ltrs.You cannot fill a lpg tank to its total capacity it has to have room for liquid to expand.
I doubt theres anyone on here that doesn't know that.You cannot fill a lpg tank to its total capacity it has to have room for liquid to expand.
I thought it was the cylinder, not the pump that controlled the 80% cut off.Ive long suspect that garage fill stations have various pressure settings and some will switch off earlier than others.
I always seem to get more gas in at my local commercial gas shop
I'm sure it does and my Safefill bottles have a float switch but there does seem to be differences between supplier's.I thought it was the cylinder, not the pump that controlled the 80% cut off.
I would have to totally disagree with you Northernraider there has been quite a few posts in past on here where they tried to over fill their tanks and did not understand why a 30ltr tank would not take 30lts.!I doubt theres anyone on here that doesn't know that.
Almost certainly a duff pumpWe ran out of gas yesterday morning so we went to fill up the 30ltr tank expecting to put in about 22/24 LTRs but only got 14 LTRs in. Anyone got an idea why and what the problem is Thanks kev
I experienced something similar the first time I tried to fill my gaslow cylinders, the problem was that I hadn't pushed the gun on hard enough before i turned the lever i thought the gun was locked on correctly but it wasn't and like you i only got a few pence in.I bought a 13kg Safefill bottle from a Funster
I tried to fill at Morrison’s Morecambe Saturday am.
I connected the gun, turned it clockwise and pulled the trigger to lock.
Then opened the valve fully and kept the red button pressed on the pump.
It took 13p but the bottle is almost empty. Released the gun and reconnected and tried again and got 9p worth.
What did I do wrong?
red button is usually the emergency stop its the black button you pressI bought a 13kg Safefill bottle from a Funster
I have done that before. EmbarrassingMaybe you released pressure slightly on the pump button, sufficient to stop the pump.
