Minxy
- Aug 22, 2007
- 32,623
- 66,460
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
I'm going to change the in-locker LPG filler on my PVC to an external one. I already have 11kg and 6kg cylinders and stainless steel pipes, so it's just the external filler that I'm debating about.
I have the larger circular filler already mounted on a bracket inside the locker (like the one below) which I could use but obviously the hole needed would be quite large so I've been thinking about getting the smaller square ones but can't decide which would be best!
There are 2 types of smaller fillers:
This one which is a flush fit and into which you have to screw a bayonet each time you want to fill up, but the advantage is that it is a neater installation:
The other type is the one that doesn't have the removable bayonet so no having to screw in each time, but it sticks out and is more limited as to where it can be placed:
So funsters ... which do you think is best?
