LPG Filler Pipe protection
Wilberforceftw
Swift 614
Newbie
Hi all
Sorry I searched and couldn't seem to find an answer.
I have installed refillable lpg and the route of the filler pipe has minimal movement but being carefully just wandered if there was anything to wrap the pipes to protect pinch points.
Wilber
If your fill pipe is anything like my Gaslow one, then it is very heavy duty and will certainly outlast Covid.
Geoff
It's not steel coated, rubber outer plastic inner. Probably just being over cautious. Just thought others may have done something.
Really appreciate you taking the time to comment.
I put the gas filling pipe trough a corrugated flexible conduit. From the filling point, goes trough a special sleeve that vents down if ruptures, and the consult carries on from the sleeve to the tank. Same from the tank to the regulator. Then, from regulator, the 8mm pipe trough a grommet entry and a bit of garden hose.
