Losing 15 years in one easy fablon wrap (1 Viewer)
Minxy
32,623
66,460
E Yorks
Carthago Compactline
I keep looking at my glass sink/cooker covers…. Mmmmmm🤔
If you want to do them do NOT remove them as they never go back properly! I found it was easier to cut the material to shape with a 1" overlap at the sides/front, use the straight edge at the rear and you can mark where the hinges are and cut out a 'U' shape to go round them, start sticking it on from the rear gradually and then when it's all on you can go round the edges with a very sharp craft/Stanley knife to get rid of the excess and get a nice finish, if you try to do it from a template you'll still end up having to trim it as the material can give whilst fitting it and trying to cut off little overlapping bits is extremely tricky.
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
van conversion, Peug
4 years
Good techy tip Thanks!
Sep 10, 2019
3,358
1,613
Warwickshire
Hymer camp c546
Since 2019
Love the fablon, we did our interior table last year, just took our time :pray: looks better now as bad few scratches, small dent, hubby put little filler
in. Light sanding then fablon. All good.:clap:
Senator12
6
4
UK
Don't own one yet
Newbie
What is the tip for applying without any wrinkles? Used Fablon years ago but always had wrinkles!
68c
Oct 22, 2019
1,813
2,787
Southampton
2001 Pilote 270
Since 2004
did you only do the front or the sides as well?
Not sure what you mean. Took the doors off and wiped down with meths then used sticky backed plastic sheet from B&Q. Covered the outside and around the edges, did not cover insides as too mean to buy extra material. The more I see it the more I like it, may wrap some other panels but probably not in 'marble' as it may be overkill.
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
Lined up straight edge , pulled a bit of backing off , start to smooth it out with credit card from centre to sides. You can lift it up and re set it if you are quick, and bubbles smooth out but if you do have one or two little ones you can puncture with tiny tiny pin hole and smooth out, (it doesnt show )
DaveFromBarrow
257
220
Aboyne
Apache 634
Since 2020
Love the idea of brightening the interior of our 2008 Apache with some wrap. Brill!
d
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
we are still learning
Have a look at this on A Kerr site...Autotrail Scout reworked to suit the customer previously I believe?
Carolyn
If fablon is the way to go check it out...........
Mar 18, 2021
49
68
Brixham the English riviera
C class
Newbie
What great transformations! I'm just plucking up the courage to do my whole kitchen at home with this D C Fix stuff. I think I'll bite the bullet now and order some gloss white. đź‘Ť
Jul 18, 2009
11,139
17,728
HYMER B644
Hi used wrapdirect.com really good quality,bit more expensive but worth it.
Sep 10, 2019
3,358
1,613
Warwickshire
Hymer camp c546
Since 2019
Our table after hubby put on the fablon, lasted well :giggle:
Nov 17, 2012
1,930
2,613
WEST SUSSEX
HYMER B SL 674
SINCE 2005
For all those owners of A Classes (Hymer) that may have an issue with the grp front bonnet fading beyond recovery this might be an alternative to a respray.
May 23, 2021
308
902
Beds.
Autosleeper Harmony
Since 2021...
Looks fabulous, seriously considering doing our table now...
