looking for overcab window for autotrail cheyenne
alan2808
Motorhome
2000 634 model passenger side- measurements are 79cm wide by 39cm high, hinge length 62cm. I have been told that the windows should have a long code number on to identify it but can't find on my window. Does anyone know what the code should be and where I might buy a replacement window either new or secondhand please?
Somewhere on your van will be a build number. Maybe by the habitation door but could be anywhere either inside or outside. Once you know it try contacting Autotrail, you will need it as it will be their first question. 👍
Maybe a pic would be helpful, same as other side maybe?
Most manufacturers use the same windows
Hi,we used to have a Cheyenne look on the other window near the bottom and you may find in the black dotted area the number from inside the van ,open the window and it’s easier to see it will be the same no as the one you have lost.
I will have a look thanks
Our build no is in the cupboard on the front of the electrical gubbins,hope this might help the OP. 2015 Auto-trail tracker
CLIFF
