Longitudinal or transverse? (1 Viewer)
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
Just a thought:rolleyes:
While browsing through some photos of motor homes on ferries I noticed there was a preponderance of longitudinal affixed solar panels. (Yes, I know, I should get out more:D). Which got me thinking is there a technical reason for this phenomenon or is it merely standardisation of available roof space?
I'm going for a lie down now. I''ll check back later:cautious:
Oct 2, 2008
4,466
7,935
Salopia
Duro 6x6 Overlander
since 1968
I think its more down to spatial configuration , as sunlight is not longitudinal or transverse , and moving vehicle will change orientation anyway . :)
ps I have two long and 1 sideways or is that 2 sideways and one long ? :D2
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Less wind resistance if you put them longitudinally, I would guess :)
ctc
Oct 12, 2015
1,512
2,529
Crowle
Hymer b680
New
How come everyone on this thread can spell? Is the question so important that it attracts only the cleverest?
bobandjanie
8,158
15,785
Javea, Spain
Pilote V600g
I couldn't make my mind up Phil, I suppose it depends on where the :sun::sun: is and how low it is.:LOL:
Someone more technical will know the correct answer, ;) so I will stay in the undecided and put one each way. :pop: Bob.
Jan 19, 2014
9,368
24,704
Derbyshire
Elddis Accordo 105
since 2014
Reminds me of:
I fitted some new wheel trims on my mums car a few months ago while it was at our house. Made the wheels look much nicer. I sent her a photo of one of them and put a foot note on "oh bugger, one of the VW badges are upside down"
She sent back "no one will notice" :ROFLMAO:
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
I rather expect that fitters (and manufacturers) fix them in whatever manner makes their life easiest, with the connections close to wherever the wires come up and laid out away from that. Without constraint (although I'm not sure that they consider shading) it would seem natural to lay them along with the line of the roof (I'm not sure that they worry too much about wind resistance, either).
I wouldn't expect 'normal' people to take the trouble to look. What's out of sight is expected to be out of mind. I'm certain that aesthetics will not come into it.
Minxy
32,623
66,460
E Yorks
Carthago Compactline
I put 2 transverse semi-flexible ones on our camper, however if I had been putting on rigid ones I might have put them on longitudinally as the fixings tend to only be in the corners so more 'strength' driving into the wind with a shorter edge ... and more streamlined not that it would make much difference with all the other gubbings that stick out from a camper!
Aug 18, 2014
23,739
133,166
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
You could have got that lateral one longitudinal behind the centre roof vent.:)Far more aesthetically pleasing.(y)
I always look at that big sloping part above the front window & think "what a waste"
Abacist
3,711
10,524
Devon
N & B Arto 88F Tag
since 2013
I put one on my last van transversely as I could get it between 2 roof lights but the 3 others were longitudinally.
Minxy
32,623
66,460
E Yorks
Martin - was the sat dish put on after your solar panels or before? Personally I'd have put the panels as far forward from it as possible to avoid shading issues, but if the panels were already on or you got the MH like that there's no point in moving stuff around.
funflair
19,294
30,058
Guisborough
MORELO palace
since 2012
The original Poly was on and I put the 3 Mono's on, the dish is never up during the day so no problem(y) the 3 Mono's are on a different controller to stop any issues.
Martin
Dec 6, 2011
11,554
25,336
South Wales
Coach built Adria
there is a simple formula for deciding;;;
you take the average angle of the sun. multiply it by the height of the roof f the van ; take away the angle at which your van is going to be parked at, add the width of your van divided by 2.
then
stick it down...(y)
Sorry!! really sorry !!:whistle:
Loveshack
135
128
[QUOTE="two, post: 3220340, member: 17624"
I wouldn't expect 'normal' people to take the trouble to look. What's out of sight is expected to be out of mind. I'm certain that aesthetics will not come into it.[/QUOTE]
Probably not “normal” people, but when “they” park you on deck, on the ferry, on outward and homeward leg of ferry to Santander, then everybody gets to look at your roof!
In my case no solar panels, just green crud.
Must get some panels.
But how to set them out ?
Taran_Las
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
But how to set them out ?[/QUOTE]
Damn good question:LOL:
Taran_Las
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
Just one of my 'moments of madness:D2'
Thanks for all the helpful:D2 and witty:p responses.(y)
:getmecoat:
