Locking wheel nuts on 138 Compactline (1 Viewer)
Wellington
676
1,667
Leicestershire
Carthago Compact 138
Are there any? I want to take out the jack and use the space (I have levellers, and European breakdown cover. If I need a tyre doing, they can earn their money) BUT I don't know if I have locking wheel nuts or something similar and if there is some doo dah I need to keep with me in order for the wheel to be changed. I couldn't see anything that looks like the one I keep in my car, but I wondered if anyone here would know?
Also, there is something missing from this box. I've never opened it before, so I don't know what should go in the space on the right of jack. Any ideas?
John H.
181
104
Hymer 578
A long time
One of the nuts on each wheel will different from the others. If the wheel brace fits all of the nuts, then you should be OK.
Interesting idea removing the jack. I could not lift the wheel even if I could get it off.
Lenny HB
52,699
147,644
On the coast in West Sussex
Hymer B678 DL
Everything is complete in the box. Make sure you take out the towing eye in case you need a tow out.
If you are not sure about the wheel nuts post a pic of your wheels, locking wheel nuts are not standard like they are on cars.
Very important make sure you know where to put the jack when jacking up the rear, as most tyre fitters & breakdown people don't and if they put the jack under the axle it could cost you a few grand for a new axle. Also not directly on the Al-Ko chassis it needs to go under the black plate the suspension is bolted too - look in your Carthago handbook.
John H.
181
104
Hymer 578
A long time
Thank you for that information. I will crawl under to have a look. I assume it is the same on the Exsis-i
John H.
181
104
Hymer 578
A long time
Always useful. We needed a tow out of the mud at one of the shows.
Wellington
Wellington
676
1,667
Leicestershire
Thank you. I don’t need to worry about a jacking point as I have hydraulic levellers. Good point about the towing eye, though. I might take the jack out and keep the spanner bit onboard to be on the safe side.
