Note: This feature currently requires accessing the site using the built-in Safari browser.
Could you not wire the permanent live feed to your leisure battery removing the "starting" issue?Hi,
I wired my cab Pioneer satnav/audio system so that it will play music with the ignition off.
How can I determine when I need to discontinue using this to ensure the engine will still start? The control panel is currently showing 12.2 volts under load.
Thanks...Keith
Try washing your car in the sun at home one day with the stereo on.. trust me the battery does not last long
However, with a little science you can determine exactly how long it'll last by measuring the amp draw of the device with an "amps clamp meter" then looking at the amp/hr rating of the battery.
Either way though, your time and energy would be better spent wiring it properly to the hab battery instead of bodging it to the starter battery and causing yourself anxiety about when you have to turn the radio off and whether the van will start afterwards..
Save yourself the bother and do it properly
Disconnect the battery.
In a word..... You can't.How can I determine when I need to discontinue using this to ensure the engine will still start?
