Lithium battery charging
Tree of life
Panel Van conversion
Please help, I am changing to lifepo batteries 2x100ah, is it advisable to charge them with solar mttp, and separately with a DC to DC charger from the alternator will these 2working simultaneously cause problems
To be on the safe side I suggest you should be using chargers that have a charging profile for Lithium batteries.
Thanks peterc10 I am referring to lifepo chargers
Tree of life Hello and Welcome to the forum.
You need to be aware that you are using up the 5 free posts that you have as a new member. If you want to say "Thank you" to someone, just use the "Like" button, and select one of the options
