Hi, thinking of changing my leisure batteries to Lithium one's , has anyone got these ?, what do you think of them ?,and where is the best place to get them from ?.
Cheers.
Mick.
Cheers.
Mick.
£3000 according to the link posted aboveTo change to Lithium you also need a new charger system
OK if you do you can run them to a lower level that the 50% discharge of Lead Acid combo's but when a 100AH battery is £1000 is it worth the extra costs
Not necessarily, some chargers have lithium settings, my Victron for example, and my Votronic solar controller has a Lith setting. But the charging regime is just one small part of the system, there are other issues like managing the starter battery charging, battery management and a whole host of other stuff.Don't forget to change your old charger for a very expensive one to go with your extremely expensive battery/ies.
They are not dangerous if stored at 100% but apparently 50% is preferred for long term storage because the cells are more relaxed in this state. My Relion battery arrived just about fully charged. Actually I think the environmental hazards of LiFePO4 are less than lead acid. There are other types of lithium battery that have different hazards and the different types are often confused.I am 100% with you Eddie, lithium has its place but 99% of applications are wrong to fit lithium, as I understand it for safety its only suppose to be transported 50% charged when supplied because of the dangerous nature,, now i know I am new to motorhomes and a few may stay forever on drives but the whole idea is moving about
Wieght wise bang for kg lithium is the best, if that is your only concern then lithium is the way to go and Relion is a good product (there is a lot that is not). If you are concerned about safety, actual power to £, reliability and durability then pure lead AGM is the only way.
Just like a Bugatti if top speed is the only concern its the car for you but if you are like most of the people out there then a German diesel will suit you, your needs and your pocket far better.
I have just purchased a Isuzu Motorhome which I will be refitting out and fitting Northstar batteries and Victron multi power electronics,,when I have some pictures I will post them
Northstar product can go down to 80%DOD but 50% is optimum it can also be charged at 3C (3 times capacity) yes you read that right.
Those are the Co variety not the Fe ones.Are they the same one`s that kept catching fire on the Boeing "dream liner"?
