Looks very neat.I bought this 200Ah one purely because it fits under my seat.
Roamer 230SEATBASE4 - 12V 230Ah Seatbase LiFePO4 Lithium Battery
The Roamer 230SEATBASE4 is a low profile 12V 230Ah LiFePO4 battery for install under a campervan seat. Includes 300A continuous discharge, active balancing, Bluetooth and plug and play integration with Victron. Free delivery, Roamercare, 10 year warranty and 5 star support from the UKs leading...roamerbatteries.com
The Roamer 230Ah battery has a BMS that can cope with 500A peak draw and 150A continuous. I haven't tested it in earnest yet and suspect I never will.If you are running heavy loads, having two batteries halves the amperage draw per battery.
That should have said 250A continuous, sorry for the typo.The Roamer 230Ah battery has a BMS that can cope with 500A peak draw and 150A continuous. I haven't tested it in earnest yet and suspect I never will.
Not sure if it is the same size? The typical 100Ah Lithium tends to be around the same cc's (L x W z H) as a 100Ah Lead.Don't overlook the simple practical aspect that lead-acid batteries are usually 100Ah or less because anything bigger is a struggle to heave in and out of confined spaces. A 200Ah lithium is about the same size and weight as a 100Ah lead-acid.
Weight yes, 26kg approximately, but size is about the same as truck battery. Other sizes are now more available, like the under seat shallow square shape.Don't overlook the simple practical aspect that lead-acid batteries are usually 100Ah or less because anything bigger is a struggle to heave in and out of confined spaces. A 200Ah lithium is about the same size and weight as a 100Ah lead-acid.
That battery is impressive, someone on another site, tested the 230ah model, and met its capabilities.That should have said 250A continuous, sorry for the typo.
