Mr Chrysalis
- Jul 8, 2016
- 2,367
- 317,717
- Rapido 890F A Class
- Since 2016, caravans before that, folding Caravan, tents before that
We do the same but if scares me .. she slipped off the clutch once, but fortunately hit the brake in time so no damage to moho or my legs.I hold the a frame and my wife drives the car towards the towball.
Alice prefers to reverse the vanto the car, using the pointing-down reversing camera to line up the tow ball and the pointing-back camera and mirrors for general view ( we have 2 screens). I prefer to drive the car to the van. If I lean forward in the seat I can see the foam at the end of the TeeDo you reverse the van to the car, or drive the car to the van? How do you see the end of the foam over the bonnet? We also have a 500 as a toad, yet to tow it!
I used to have a jockey wheel (Armitage's) on the Smart Car, but as my tow ball is only about 2 inches from the plastic rear of the van, we had to be very careful, especially as the Smart had automatic gearbox and hence no clutch controlMy a frame has a jockey wheel so I can either drive up to hitch or leave
a frame down and reverse mhome to hitch and with camera can line up mm perfect.
I can do the same with the arm held up ( horizontal) with a strap, but As there is only about an inch between the "cup" on the A frame and the van when located on the ball, I would only have to overrun by an inch to hit the van. As I cannot fit a bumper guard, I prefer to risk hitting it with the foam on my plastic Tee thingA frame held up by strap, reverse motorhome and line up using reversing camera, release strap, clunk. OK I might from time to time need a second shot or to pull or push the car a tiny bit but not often enough to worry me.
Luckily for me my ball is comfortably clear so I have room to overshoot a bit.I can do the same with the arm held up ( horizontal) with a strap, but As there is only about an inch between the "cup" on the A frame and the van when located on the ball, I would only have to overrun by an inch to t
Hit the van. As I cannot fit a bumper guard, I prefer to risk hitting it with the foam on my plastic Tee thing
I used to have a jockey wheel (Armitage's) on the Smart Car, but as my tow ball is only about 2 inches from the plastic rear of the van, we had to be very careful, especially as the Smart had automatic and hence no clutch control
Alice @Chrysalis agrees with you!I prefer to reverse onto the a frame, a better overhead view from the camera so more accurate.
I drive and wifey holds the A frame, much safer!!! (wife don't drive )I hold the a frame and my wife drives the car towards the towball.
I always preferred to reverse the MH up to the A frame with the aid of the twin reversing camera. Having a jockey wheel on the frame and set higher than the hitch ball it seemed the easiest way.
I have a Smart car & I have heard others mention the lack of clutch control. It isn't something I've ever noticed. Simply hold the car on the brake (foot or hand whichever suits), increase rpm until the car wants to move then without moving the throttle use the brake to ease forward. Just like you would with a conventional automatic in fact.I used to have a jockey wheel (Armitage's) on the Smart Car, but as my tow ball is only about 2 inches from the plastic rear of the van, we had to be very careful, especially as the Smart had automatic gearbox and hence no clutch control
Maybe a piece of plywood, padded both sides with u shaped cutout to slip over swan neck while coupling?I would do that if I could find a way to fit a bumper Guard but can't risk overrunning by an inch and hitting the van body
Yes thankyou. I have used a garden kneeler, but difficult to hold in place. Plywood is a good idea but it would have to be big enough to spread the force, and because of the shape I would probably need suction cups to hold it upMaybe a piece of plywood, padded both sides with u shaped cutout to slip over swan neck while coupling?
Malcolm
I think the important bit is that you have already found an ingenious method that works for you. It may also work for others who have similar problems. Thank you for sharing this.Yes thankyou. I have used a garden kneeler, but difficult to hold in place. Plywood is a good idea but it would have to be big enough to spread the force, and because of the shape I would probably need suction cups to hold it up
Yes, but surely that leaves no room for the jacuzzi?My new van allows me to put it in the rear bedroom with folding beds, great innit?
QUOTE]
You changed your van then Griff
I see, a roof mounted Jacuzzi. Very clever. Also handy to pull the plug just before you leave site to wash down the van I suppose?Now you're just being silly, the Jacuzzi is further up, but I don't carry enough water to fill it.
