Lights out.
Lincolnshire
Hymer grand canyon
Since 2009
Firstly.... Happy New Year to everyone on here.
I have a Hymer Grand Canyon and we are currently away in the slaps. On the way here we stopped and had a very enjoyable Thai takeaway on the way to the chunnel and all lights were working perfectly. We drove a bit further to Folkestone, pulled up and found that all the lights on the shower side of the van don't work! I blame the massive pot hole we nearly lost the van in around Tonbridge.
Can anyone suggest anything please?
Check your fuse box?
Are the things affected all “switched live” (only work with the ignition off)
or
permanently live (always able to be switched on)
That’ll at least point to a particular circuit.
or
Nothing has tripped out.
If its a hymer as per OP it's unlikely that anything in the hab area will be switched off with the ignition on which is a peculiarity of British ones. On mine the light immediately inside the door works even with the panel off, all other lights are on the same fuse, though yours may be different. Check fuses first, with a meter as it's not always easily visible that one has blown.
On our. Burstner if a hab circuit goes out, turn the hab electrics of wait 1 min turn back on again. These are resettable trips (2019)
