Levelling motorhome without air suspension (1 Viewer)
Grianan
Feb 18, 2018
3,256
10,518
South Ayrshire
Globecar Campscout
Since 2018
Thanks for replies .. I’ve edited post to explain why I need help with this ...
jollyrodger
6,242
28,406
Devon/Cornwall
'Obby
Since 1968'ish
A large glass of brandy stand it on the table if not level drink from the high side .
Keep doing this ,replenishing your glass, when necessary.
Eventually everything becomes level ish :LOL:
two
Aug 4, 2011
4,794
4,410
West Midlands
A-Class Fiat
Level is not critical. Do it by feel.
There are some apps that look good. You could use one of those if fussy.
If you prefer to have your head higher than your feet when in bed, bear that in mind.
The tin of beans method requires the tin to be on its side, by the way, and then needs to stay put rather than roll away. If it does roll, it will be OK if only slowly and towards to foot end of the bed (roll it on the table, not the bed).
(Do I really need to be saying all this? :))
Edit, after seeing the added information:
Water in a saucer can be a simple way to check. This and the beans assumes that the table top and your bed are level at the same time.
If all else fails, use the Brandy method for a sound night!
Zigisla
2,558
3,356
Gosport, Hants
Sunlight A72
Getting better month by month.
Buy from Amazon - place on table or known flat surface - move MH til bubbles in the middle. Done. Unlike this one but was for the pic only. :rolleyes:
Jul 11, 2016
402
345
Worcestershire
Burstner Ixeo TL680g
returnee
The free truma app has a levelling feature that tells you how much each wheel is off level so you can figure out how far you will need to go up the ramp
Rosemary1
1,427
4,152
Dumfries and Galloway
Rapido A class
1 year
Hubby uses one of theses, but I must be very insensitive to levels as the van always feels level to me - even when hubby curses and uses the blocks after reading it.
Grianan
Feb 18, 2018
3,256
10,518
South Ayrshire
Globecar Campscout
Since 2018
I think it's the editing you need help with.:D2
I managed the editing just fine @LennyHB but then decided to delete post ... no option so managed next best thing. ;)
Edited to say .... you could help with deleting posts though? :p
Grianan
Feb 18, 2018
3,256
10,518
South Ayrshire
Globecar Campscout
Since 2018
Thanks Mark, that looks like the sort of thing we could do with.
Aug 27, 2014
1,875
3,307
Shropshire
McLouis Tandy 640+
Since 2014
I parked my van up on ramps one day so it was dead level (checked using a spirit level on the floor), then permanently fixed a little Bulls Eye spirit level (like this) to the flattest bit of the top of the drivers door trim, next to the window, mounted on a blob of Sugru - so it was perfectly level.
Works a treat, gives me an instant and easy level reference every time I park. Often on uneven ground I just keep an eye on it and move the van until it shows level, save bothering with ramps.
Grianan
Feb 18, 2018
3,256
10,518
South Ayrshire
Globecar Campscout
Since 2018
Sounds ingenious .... thanks!
Lenny HB
50,153
138,166
On the coast in West Sussex
Hymer B678 DL
Why delete the opening post in a thread when you have had loads of replies - mad..
Oct 24, 2015
4,523
20,459
Helgas house
hymer e650 battered!!
None
I like mine slightly leaning towards the right!
So the water runs off the roof if it rains,,
Only problem is I don’t sleep very well being nearly upright!! And the fridge door being permanently open,, and the cassette dripping out under the door!! But no rain stays on the roof!! X
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Since 2015
So, what the fook is the question?
I think it’s just help in general you need
Grianan
Feb 18, 2018
3,256
10,518
South Ayrshire
Globecar Campscout
Since 2018
Thanks Lenny.
I had edited to add medical reasons for questions so people who replied understood why ‘if it feels level it’s ok’ won’t work.
But, on reflection I felt uncomfortable with putting it out there when I haven’t yet come to terms with diagnosis.
So mad, maybe, if it offends you I apologise.
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
Thanks @ABZSteve for your input see #21.
I would like to know best way of getting van level without air suspension and would be happy for any advice, if you have any
I only ever use levelling ramps. Use 6” sprit level to check and s just as necessary.
Lenny HB
50,153
138,166
Hymer B678 DL
Thanks Lenny.
No offence just seemed odd to delete the post and leave it blank.
Apr 27, 2008
11,702
13,625
Eastbourne East Sussex
Hymer low profile
Since 1972
Were not too bothered about being exactly level and are usually able just to move a bit to get reasonably so. Unlike many on here I prefer to have my feet higher in bed so I don't slip down. The kitchen sink drains better like that too.
Oct 8, 2014
1,522
2,725
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
We place a marble on the slightly textured work surface. If it stays still, then it's level. If it rolls slowly, we probably live with it, but use ramps or move the van slightly if it rolls quickly in any direction.
Minxy
31,926
63,432
E Yorks
Carthago Compactline
... have you ever lost your marble ???? :D2
Minxy
31,926
63,432
E Yorks
E? This is about morse code isn't it?
Minxy
31,926
63,432
E Yorks
