eti in europe
Hi just woke up my hymer b544 after a long time because of Covid. Engine starts but no lights or steps moving. I had the fuse box switched off during hibernation. Any help really appreciated
The switch on the control panel turns off most, but not all, of the habitation circuits. The step, frost protection valve and possibly the fridge control board are still powered, unless the battery is totally flat or the battery off switch on the Electroblock (EBL) is switched off. If the step doesn't work then you've lost all power.Hi just woke up my hymer b544 after a long time because of Covid. Engine starts but no lights or steps moving. I had the fuse box switched off during hibernation. Any help really appreciated
A hab relay is a relay that cuts off all the habitation circuits when the engine is running. If it fails, then, sure, it could cause such problems. Except that Hymers don't have a hab relay. It's a Brit thing.Another forum thought it could be the hab relay has anyone any info on that?
Hi it seems the on off switch is not switching it’s mounted on a pcb in the ebl. The next problem is I was hoping to get it serviced next week and would need to drive it to the local garage to do that. Do you know if it will run safely with unit disconnected with the power wires all taped up. I was going back to England at the end of next week so could take unit with me and try and get it repairedHi seems all things fed by the leisure battery steps and things
If the spilt pin is removed from the underside of the step it allows the step to be hand pushed to the retracted position allowing it's retention.Tried to get a bit of wd on and kept switching. Just managed to get the meter on the pcb just managed not to throw it against the wall lol. The next problem is the step is down but think I can get it off and tape up the switch. Having a great day I hope this promotes me from newbie Don’t know if anyone knows of repairers in England?
The two power wires to the base of the EBL (Starter positive and leisure positive) are protected by big fuses, probably 50A, near the battery. You could pull these fuses as an extra safety measure. Be careful with the colour codes. Hymers have brown = negative, black = positive, although the starter positive is red, I think.Do you know if it will run safely with unit disconnected with the power wires all taped up.
Hi there eti in Europe, there are a couple of companies in uk that repair the electroblok, the one that springs to mind most is A&S or A&E caravan services they are based in North Wales and are specialists when it comes to overhauling Electroblok control boxes, if you send it to them the give you a price last I heard it was approximately £140.inc return postage, and they turn it around quite quickly or they used to do an exchange for a similar price. Give them a ring and speak to Andrew.Tried to get a bit of wd on and kept switching. Just managed to get the meter on the pcb just managed not to throw it against the wall lol. The next problem is the step is down but think I can get it off and tape up the switch. Having a great day I hope this promotes me from newbie Don’t know if anyone knows of repairers in England?
