Taff763
- Sep 14, 2019
- 3
- 0
- Bailey Approach 750
- Since 1989
Hi All
I came home from France yesterday and everything had gone great on the holiday until I got home and switched the ignition off on my 2014 Bailey Approach Autograph 750, the control panel above the door was stating that the leisure battery was low showing 11.2v, the fridge was the only thing on, which had been on for a 13hr drive including a 1.5hrs ferry crossing which would have been off at this time!
I recently converted a VW T5 and wired all the electrics myself including a split charge relay system for the leisure battery so class myself OK with the electric side of things. But for the life of me can't find a blade fuse or relay for this system. I have placed a volt meter across the vehicle battery and when ignition off shows 12.1v and when started shows 14.1v so is charging OK. The 2 x leisure batteries show 12.9v with nothing plugged in and nothing switched on, but when the mains hook up is plugged in it charges fine up to approx 13.2v but when the vehicle is running the leisure batteries don't charge they just stay at 12.9v. All day I have checked all the fuses, no terminals have rust, I have traced all wires and have good continuity but still can't find why the batteries don't charge. The only thing I haven't done is opened the mains charger unit.
Has anyone had this problem before? What did you do? Where is the Relay or fuse? Sorry for the long winded post but would appreciate any help or am I missing anything? Thanks.
