Hi All,
I purchased my campervan conversion. Zero history. Are leisure batteries not great is my question?
I installed a new 100ah leisure battery deep cycle.
I have split relay charging and a 100w solar panel it seems.
My question is that when I go into the Van the current charge on the solar controller is 0 Amps. I put the van to Van mode and the fridge kicks in which is the only appliance on the circuit. That and lights which are off at this time. and within 10 seconds it goes from full LEDS (PMS v3) to 80%. I switch off Van mode.
The solar charger kicks in and right not jumps up to 2A. I see the battery climb 14.1,.14.2 to 14.9v and then solar charge drops the amps and the LEDs are full again (1 red and 4 green). When it does drop from 100% to 80% it flickers between both LEDs after 5 seconds of being on.
It does this each time. I have had a replacement battery as I was unhappy with the results. It did arrive 50%+ charged etc... but the same behaviour with the new one.
I did some electrical work this weekend etc... so examined the connections and make sure everything was solid on the back of the PMS v3 etc.... All good.
I have a 2 way fridge installed as part of a previous professional installation I am advised. When I checked the model number from the manuals this fridge ranges from 1.5 to 1.9amps when in use. This is the only device on the system.
I have now installed DC sockets as of yesterday straight to the leisure but these are switched so no load apart from cable.
But this has been the behaviour each time hence why I asked for a replacement battery. I have not taken it out in anger yet as in not on a site etc... but this does seem like very odd rubbish behaviour based upon there only being a fridge in that range from the manual (and guessing which one as there are there are 3 in manual .. but this is best visual match).
Can some peeps please advise as I cannot believe the leisure battery would drop to 80% SOOOOOOO quickly.
And when we were working at the weekend on the van. No lights on.. lovely day... but taking clips off the batteries for safety whilst testing... the battery got to 50%. No load.
Please advise... new to this so I don't have a benchmark but think with these numbers there is no way this battery should do this so quickly.
Maybe this is because it is <100%... ok fair enough. But alarmed to see it get to 50% when NOTHING was on.
Many thanks in advance... ALL comments very much appreciated as I am in the dark when it comes to experience.
R
R
