Leisure battery charger location
Dazza50
Swift Kontiki 669
Can someone please tell me the location of the charging unit for the Swift Kontiki 669? . I can't find it anywhere 😭
Solution2
From looking around it seemed Swift used Norrelectrica for a while and due to having issues they switched to sargent
a bit ropey I know but this seems to suggest combined version
edit but then this which has your numbers says not...sounds like you're flogging a dead horse, and a possible sargent replacement may be the best bet
It's the leisure battery charging unit.
I don't have the Sargent, mine is nordellettronica 🤔
I see the unit has a charger MCB & switch, could it be in the unit as the unit does look quite deep) or you may need to follow the wires.
Have you checked all wardrobes etc.
What problems are you having? no charge at the LBs? looking round these units seem to have been unreliable.
Upvote 1
I have checked wardrobes,, but can't find anything. Got an engineer coming out tomorrow, wanted to pre-empt the 3 hour search for it, especially at price per hour 😂
This maybe of help.....I have swift bessacarr e420 with sargent ecu. The charger is behind a panel in a cupboard at floor level. It is virtually directly below the ECU. It maybe that Swift/Sargent design all their sytems in a similar way/layout. Who knows??!!! HTH
Upvote 1
Solution
www.olearymotorhomes.co.uk have a Swift surplus stock MCU-S for sale and it is described as a Mains isolator with no mention of it being a charger so I think maybe the actual charger may be elsewhere as has been said.
Tombola beat me to it !
I wonder if it could be in the section behind the fuse box ?
