Leisure Batteries (1 Viewer)
May 7, 2011
5,530
28,606
East Anglia
Kontiki 669
Since 2010
Jan 8, 2013
8,400
11,387
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Everybody has their preferences.
I would buy these
Feb 14, 2021
2,931
6,111
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
Varta are a good name. My new Burstner came Varta batteries.
I've used these suppliers in the past
And also
Sep 16, 2010
2,953
2,771
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
My 2 Leasure batteries failed whilst we were wintering in Spain. Varta sent me replacements, by courier, direct to my van in 4 days !!
ÂŁ210 INCLUDING delivery, which was ÂŁ37 !!
I think that says it all.
Mitch
Apr 27, 2016
6,562
7,425
Manchester
A class Hymer
Since the 80s
Another good place is Alpha Batteries. They do deliveries like the others, but you may prefer to go and pick it up in Rochdale, not too far from Stockport.
Jan 8, 2013
8,400
11,387
Burstner Lyseo 690G
Are they just classed as leisure batterys or do i need a particular size?
You simply need to make sure that it will fit in the space.
What Ah is your existing battery? It should be written on the top or side
Gellyneck
8,997
17,659
Scotland
More than toes wet now!
I replaced our original Banner leisure battery with a Varta LFD90 a couple of years ago. Got it from Alpha Batteries (link above) as they were cheaper than Tayna at the time. They were very helpful when speaking to them on the phone.
Think the LFD90 has now been superseded by the LFD95.
Jaws
23,765
74,888
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I buy about 10+ batteries a year for various applications
Always use Tanya and always happy with the service
As to make, depends what you can afford. but generally, like all things in life, the more you pay the more you get
Simon Meadwell
Jan 28, 2016
2,397
2,767
Stockport, Cheshire
Bravaria i740 AClass
Yes I agree.
Mar 30, 2019
2,697
4,951
Cardiff, UK
Since 2016
Hankook from Battery megastore for mine, 110amp approx ÂŁ85 each, free delivery. As recommended by others on here.
Nov 21, 2021
374
1,470
Co Durham
Autosleeper Amethyst
Newbie, former van camper and still wild camper
Used Tanya batteries a few months ago for a 100 amp platinum ÂŁ100 delivered to the door in 2 days.
RedFrame
1,080
3,156
Chester
Self Build W907 PVC
Sept 2017
Another vote for Tanya here!
I would suggest measuring the existing battery and make a note of where the positive and negative terminals are and it's Ah which will be written on it, then giving them a call... or you can use the filter on their website...
You won't go far wrong with Varta.
Red
Aug 5, 2012
118
125
Hitchin
Swift Escape 644.
since 1970's
Need to replace my lead acid batteries any ideas where from. I have been advised to buy varta
Hi I have used Halfords for the last 13 years on all my battery's mainly because its easier to return them if you have problems, but had none so far.
Feb 25, 2018
5,455
12,018
Essex
Adria 670 SLT
Is it worth considering getting lithium? You prob only need to buy one to get more available Ah to actually use? Though of course it will be close to twice the cost, possibly even a bit more ...
Jan 8, 2013
8,400
11,387
Burstner Lyseo 690G
Solar controller will look something look like this. Wire's from the solar panels and wire's out the battery.
RedFrame
1,080
3,156
Chester
Self Build W907 PVC
Sept 2017
I am an electric luddite due to my Dad being a spark always doing jobs for me. I dont know what the controller looks like
Perhaps it would be worth finding someone to help you that is a little more knowledgeable. That way you know it's right and you'll learn how to do it for next time? Where are you based?
In fact you're only in Stockport, I'll send you a PM.
Red.
Nov 4, 2011
5,694
38,976
Uk
If it's daylight just disconnect the wire from the solar panel into the solar controller before you start... And reconnect it last 👍
I’ve believe it’s not good to disconnect solar panels when under load, it can damage the regulator.
If I’m going to remove batteries I disconnect the solar panels the night before.
Jun 19, 2021
127
7,295
West Wales
Expedition 66
Nee
My battery is no longer holding its charge. My fault entirely 🤦🏻‍♀️.
How easy is it to install a new leisure battery? I’ve changed a car and ride on mower batteries before, is it just as easy?
Apr 27, 2016
6,562
7,425
Manchester
A class Hymer
Since the 80s
Yes, but a couple of points. If the new battery is a different type to the old battery, (wet, AGM, Gel) you may need to set the appropriate profile on the charger. Or restrict your choice to the same type as the old one if there's no way of setting a profile.
If you have solar, your solar controller might have to be connected in a definite sequence so that it recognises the battery as a 12V type, not a 24V one. If so, disconnect one of the solar panel wires, then connect the battery first, then the solar panel wires.
Greasy Chap Butty
171
2,538
Boxer
If they already have all the charging set up installed, it could be tricky?
