Oldgustaf
Any thoughts about why the leisure battery isn't charging when driving? MH is 2021 Mercedes chassis Hymer ML-T. Asking for a friend. Dealer not being very helpful. Thanks.
The gas whilst travelling is only an option if you have both a crash sensitive regulator and rupture protection on the bottle.I had the same problem with My 1 year old pilote , it is the smart alternator , they will have to fit a B2B charger , what makes it worse is when driving as the fridge switches to 12v so depleting the battery with no charge going in , if you put the fridge on gas as opposed to A (auto) it helps a lot , this is a well known problem , the dealer will know this !
my MH did the same thing (not charging leisures when driving), it was the fuse on the starter battery that had blown.This MH is newish, and might have the older 'split charge relay' charging, or (if it has a smart alternator) a charge booster (B2B charger). Either way, the first thing to check is the fuse in the main supply from the leisure battery, probably a 50A fuse near the leisure battery. Then there will be a fuse in the supply from the starter battery/alternator, probably a 50A fuse near the starter battery.
The next step will depend on the charging method. Does it have an Electroblock (EBL) like most Hymers, if so what model number is it? Can you find out if it has a charge booster (B2B)?
