Leisure batteries. Best buy
Bessacar E765
Do we have any suggestion regarding The best Leisure batteries for wild camping. I have 2 105 ah at the moment with a solar panel to keep them topped up.
They have been on for 4 years and think the are on the way out.
Rik East
I went for a gel battery for the deeper discharge, longer life and no venting. Not so good if you've got a big inverter though.
Upvote 1
Rik East
Whereabouts are you?
I think my leisure batteries are defunct too. Showing a full charge yesterday but this morning!! I purposely left the inverter on last night with nothing drawing 230/240 volts just to see what would happen. I presently have 2 x 125ah leisure batteries with both stud & post connections, I'd like to replace with similar to avoid having to re-make off the connections. I believe the batteries could be quite old.
I'm also having issues with my Computer Management System 2000 in that it's not working at all but sometimes makes a chirping noise and flashes the message Bat/Low.
Measuring the voltage of a battery is easy but i's capacity to store is more difficult I believe.
There's no sun on the solar panel yet :)
Measuring capacity to store is easy, 55w car headlight bulb connected to battery, measure the Voltage every hour. The bulb is a 4.5A load, a 100AH battery should give you 50A, so 11hours before the Voltage starts to drop below useable. Mine lasted 1hr 10mins!!
Jim
Lots of impartial info from these guys
aandncaravanservices.co.uk
No connection just a satisfied customer.
Jim
Thanks Jim, I should have thought of that but often 'can't see the wood for the trees' :)
We used to have a heavy duty tester in my workplace, a pair of copper spikes with a heater in between - any batteries that were u/s would show up straight away.
When I went out to the van this morning, the voltage was 9.9v - that's two identical leisure's connected together! I've now disconnected the solar and I have them on charge. My suspicion is they'll show a good voltage but won't handle much of a load and replacements it'll be.
We've only had the van a few weeks so never used it in anger (no hook-up), Malvern would have been the first.
My leisure batteries are currently on charge before I attach the headlight bulb just purchased from Halfrauds, I'll then take hourly voltage readings as suggested by Happy Jim :)
Took a look at leisure batteries while at Halfrauds - how do prices compare to online?
Check out Varta LFD deep cycle leisure batteries.
I was very, very pleased with mine which I bought through Tayna Batteries.
JJ :cool:
