- Aug 29, 2019
- 211
- 89
- Mirage 5000 A Class
- Since 2019
Just brought van from storage to give it the once over. Hopefully will get out in it soon.
When I turned pump on found water leaking from tap in bathroom. Seems to be coming from the tap itself rather than pipework so was wondering if it is repairable? Maybe a washer somewhere in tap?
Only leaks when pump turnend on. Can I just remove tap by unscrewing from underneath, or do I remove metal pipes from plastic pipes first?
Any advice welcome, including where I can get tap from if it needs replacing.
Thanks in advance.
Thanks in advance.
