Leaking drain
Mandymackenzie
Devon
Swift lifestyle
Just had my motor home back from a hab check were away now and noticed when water is draining from the kitchen sink its just pouting out side .tried to look under see were its comj g from and it dosnt seem to be connected to any thing drain just pouring onto floor .was ok before hab check .i know nothing about fixing stuff like this any ideas please thanks
w2f
I think it's unlikely the hab check would involve disturbing the waste pipe.
More likely a freeze over winter pushed a connection apart ?
I dont see amy other pipes around it that it may have come disconected from .
Maybe you could post a photo of the likely area, and someone might spot where the pipe has disconnected from.
This is all i can see under the van .too old to climb under any further lol waters coming out of this cant see amy pipes round it
How long have you had the van? That looks like the proper waste outlet? Could the hab check guys have knocked the release tap for it?
On our swift outlet looked like that bit had another part attached which had the emptying tap on. Have you gone over any rough ground? I managed to knock ours off going over a hump on a campsite.
Does the water from the bathroom washbasin also come out of there? If it does, that means it's the waste water tank outlet, not just the kitchen sink drain.
Is that not the grey water outlet ?
What do you think is broken ?
From your original post I got the impression the water was leaking inside the van from your kitchen sink.
Can you clarify
Dropped/ been pushed down. Is the grey water tank still close to that end outlet?
Mike.
