Leak from water pump (1 Viewer)
Badboo
89
11
Northern Portugal
McLouis Mc2 72 motor home
This our first!!
Hello all,
We have discovered a leak in our SHURflo water pump.
When the water is turned on at a tap water is also observed escaping from one of the pump parts (see image attached). I screwed the part tighter and it seems to have stopped the leak but would be interested to know what the part is? There are also two plastic "leads". One is red and the other is green. They are both capped but are not secured to anything. I'm not sure if this is correct?
Additionally can anyone suggest the best way to get in and dry out the floor under the pump?
Thanks in advance!
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
It appears to be a inline water filter/strainer
Is your photograph looking down onto the pump and filter/strainer assembly?
Martin
andy63
4,672
15,017
south shields
None
since 1990
Another one for the inlet filter ... they often leak and just need a little tightning....hand only..
Best I can tell from photo the wires you are refering to are both in a connector...joining them to another wire... looks like a cap type that just screws over the wires after twisting them together....
To dry out I'd suggest just mop up with tissue and then use a hot air blower... pinch a hairdryer:LOL:
Andy...
Badboo
Badboo
89
11
Northern Portugal
This our first!!
Andy...
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
Thanks..
Yes looking down from above
So not the easiest access to dry it out, stuff some bits of paper down first and then plenty of ventilation.
Martin
43,323
49,427
Wires are as Andy said......a lazy and very shoddy way of connecting two wires in a screw cap isolator.
Should be soldered or in crimped connectors and insulated.
Jan 22, 2009
75
64
banbury
c class
Not sure about the wires but the filter is bowl has an o ring that could have been pinched causing it to leak easy enough to change
