Kitchen tap replacing
How does one go about sourcing a replacement tap? What specifications are there?
What’s the problem with the tap.
If it’s not starting pump it’s most likely a broken wire to the micro switch which maybe repairable or replaced.
It's a barwig tap defleff motorhome.
It's leaking and it's split internally or seals have gone.
I ordered what appeared to be the same but the fixings were nut and bolt to the sink but the one I have is screwed in.
This? It says 'shower' but looks the same as yours.
<Broken link removed>
that looks like a comet tap, and the fixing nut is usually loose, not glued to the sink. I source replacements on ebay usually
