Keeping your car battery charged when you are away for several weeks.
Taunton
Newbie
Hi all, I was wondering what other members do when they are away for several weeks at a time to keep their car battery charged?
Having retired 18 months ago after one of our early trips when we arrived home our car battery was flat! This year we have had a couple of trips of 6 weeks away, my son popped over and ran my car for 15 minutes to keep the battery healthy. The car is left on our drive so easy access but I don’t feel I can ask him every time.
There must be a better way, what do all you intrepid travellers do? Thanks
Do you have solar? A dual output solar controller can be connected to the engine battery or fit a Battery Master ( other makes are available)
We have a small 10 watt panel which we have on our garage roof, this with a long lead reaches directly on to our Audi Estate which has the battery in the boot. This has worked well for nearly 7 years, and as we were away for up to 6 months at a. Time the car always started no problem. Though our car does shut down various accessories to save power.
I used a small solar panel plugged into the obd socket and that kept it topped up, just don’t leave the car open with the keys and the house key on the front seat for 10 weeks like I did….😎
I have one - it seems to work
AA Solar Charger
I got an OBD one as in my car [as many others] the 12v socket isn't live when the ignition is off.
it's 1p cheaper now than when I bought mine, 7 years ago - inflation pah :LOL:
A long time ago now we used to have a purely pleasure drive sports car and I had to keep the battery charged because of the draw from the alarm system when not being used. The charger was suitable for long time charging for the likes of what I was using it for, motorcycles and lawn tractors etc. HERE is the blurb on their website.
So when away now I use the AccuMate charger I bought specifically for that job and make sure I attach the leads as recommended in my car’s manual. I have never had a problem over the past 10 years. I have long, extendable leads, so could keep them inside the engine bay if necessary but I have mine in the garage.
Not battery problem. Car started first time after 3 months
The problem we have found with leaving a modern diesel car sitting around for 3 months during the height of summer is the AdBlu crystallises.
Luckily all fixed under warranty, but it involved a new AdBlu tank, new filter and new AdBlu plumbing as well as three visits to the dealers and the car off the road for 3 weeks awaiting parts.
I found out from the dealers that they had 4 other cars in their car park at the same time as mine all with the same problem.
Apparently Citroen could not make the spares fast enough, but were faster than Peugeot and Vauxhall who use the same parts and had cars waiting weeks and weeks.
When we go away next year I'll be leaving the car with a friend to drive it around every week or two.
The last twice we've been away for months at a time, I connected an Aldi/Lidl multi-stage Smart Charger to our old Pug 206's battery.
It has a cold weather trickle charge setting, which seems to do the job fine.
We come back to a car ready to start and move off the driveway. I just print off an A4 label "CHARGING IN PROGRESS" which I lay on the driver's seat, to remind me to disconnect the charger when I come home. ;)
Cheers,
Jock. :)
Re the above post 11it would suggest you should do the same with our new 22 onwards Ducato Motorhomes. Thanks for adding that info Brains
I just hookup my normal battery charger which is powered through a timer switch for one hour a day. Not happy with leaving something connected all the time TBH. Battery charger is on the drivers seat along with the cover so I, or anyone else, don't forget.
Thanks but silly question but is is the obd socket?
We leave my old car parked up while we go away for up to 11 weeks, it has always started when we got back as has Johns which has been garaged. He did buy me a little solar panel to help, but knicked that as his bike battery is not so reliable.
I used to use a little 10w solar panel. My current vehicle is practically unique in having a lithium battery with zero self discharge. It has to run the alarm etc but if it really goes flat it can be started from the main traction battery with a dashboard button, though you do need to fiddle about with the emergency key to get in.
Just Google 'dashboard solar panel' plenty available,running it for 15mins is probably the worst thing you could be doing.
Note that 15 minutes of idling won't put much back into the battery. You're much better off with a maintenance charger (or little solar panel). You can also disconnect totally, but modern cars sometimes throw a wobbly and spew badly designed ECU units all over the drive (figuratively speaking).
I left mine in the garage but unlocked and it started okay 10 weeks later.
AA Solar Charger
That’s the one…👍🏼
On board diagnostic’s socket, usually under the dash by the fuses..
CTek make the best battery conditioners out there ... if you have access to power on the drive, this is all you need. Just make sure you choose the right one if you have an AGM starter battery (with stop/start) 👍
https://www.ctek.com/uk/
Our little 107 sits in the garage at MiLs quite content and still starts up fine.
I disconnected battery only takes 2 mins to do, reconnected on return no problems didn’t even Need to reset clock.
I've left my car for 8 weeks, and plenty of life in the battery when I returned.
our little kia just gets left to fend for its self we left it for 9 weeks from march and it started fine when we returned
With ours the 12v battery gets charged by the HV battery. The recommendation is not to leave it undriven for more than 3 months.
[NB - This might not be foolproof according to the forum members who have experienced flat 12v batteries after a few weeks. Cars with keyless entry may refuse to unlock etc. ]
Our car is 10 years old still on the original battery always starts first turn after 6 - 7 weeks away.
