jokon light fittings
sleights
c class
I'm fitting a reversing camera. I looked behind the bumper there is one reversing light on the other side is a wire the same colour and its on a light connector with a blanking plug in it which supplies 2v when in reverse so it looks like the base wiring was set for 2 reversing lights. I could just chop it off but does anyone know if there's a plug I could buy to just plug in. Heres a pic
That looks like it is designed to fit the fittings so unless you were to find a fitting (for cutting up to make one) I'm not sure there will be a connector available for it. Maybe cut it off and keep it. You can then use the unused circuit for the reversing camera.
Wago 221s in a Raytech gel enclosure (Google them) although it would probably be just fine with the 221s.
