I have a spare you are welcome too. It's from an older model but should still fit.
Bath isn't too far from you. PM me to organise collection.
It was a clean break, and it almost looks like it had a shroud or covering, but I couldn't find anything on the ground. It will not press together, the two parts are of the same diameter. It would probably need an insert and outer cover to hold. Thanks for the idea thoughLooks to me like whatever was on the end was only pressed on.
Push it back on, drill a hole through the lot and put a small but and bolt through the hole.
Ok....it was the ring and slightly different colour which made me think it was two tubes pressed together.It was a clean break, and it almost looks like it had a shroud or covering, but I couldn't find anything on the ground. It will not press together, the two parts are of the same diameter. It would probably need an insert and outer cover to hold. Thanks for the idea though
I agree, but if I can fix it in the longer-term I will, right now I could do with a working one, and it looks like I've got an answer thanks to Bucket. I had just oiled the noisy gearbox, was just winding it in and out, and it snapped off easily. It's not that cold, so it must be that it's just weak. Luckily it broke in the closed position.Ok....it was the ring and slightly different colour which made me think it was two tubes pressed together.
At a push another piece of tube either inside or outside then drill and bolt both ends
I hate throwing things which can be fixed.
