- Feb 14, 2021
- 4,456
- 10,068
- Burstner Lyseo 727G
- 3 years 30,000 miles UK and Europe.. Campsites and off Grid.
2021 Ducato based Burstner Lyseo question:
I was intending to disconnect the Hab battery while we are away on holiday and the MH is at home on the drive. Didn't really want to leave the EHU in. However, access is a nightmare. Removed drivers seat from runners but the swivel plate is very sturdily attached - 6 hex bolts and then 2 bolts which are flat headed and welded to the plate so only access is from underneath - inside by the battery!!! At this point I gave up. Pity because I was also exploring the possibility of adding a 2nd battery under there.
Anyway, there is a 50 amp fuse under the seat by the battery - if this is removed is this effectively doing the same thing isolating the battery or will there be other consequences?
