Smunkey74
- Apr 8, 2022
- 25
- 26
- Searching
Ooh, that's not much when you add in 2 adults, 2 kids, a dog, bikes and everything else you need to takeCertainly no expert on these - but if it’s plated at 3500 kg and a claimed 400kg payload (quick google search) I think I’d want a weighbridge reading to check it’s actual payload with fitted extras.
Hi all. I'm just looking for our first Motorhome and this Niesmann has caught my eye but it does look a little unloved and I'm not sure if that is damp at the bottom corners of the rear window.
Any advice would be very much welcome, thank you.
That garage floor looks new so check underneath as it could have rotted.
Check all exterior locker doors for leaks especially the large garage door.
It was the build quality and reputation which originally attracted me to this vehicle.You’re bound to find a vehicle which suits your needs.
I’d second what Nicholsong said about Niesmann vehicles - you might find a larger one with better payload.
Good luck with your search…
Would 4000kg be enough though? I'll have a chat to SVTech and get an idea.
Better payload with a Flair Geoff but the price/size/weight generally goes up as well.Newer Artos go to higher weights but probably not in that price range. There may be slightly older Flairs which might have the payload - funflair could comment on that as he had one, before he went extra posh with his Morelo.![]()
Yep, completely agree. There do appear to be older vans which have been much better cared for.Just my opinion but regarding points 1 and 5 you should bear in mind that the van is 20 years old.
I don't think i would be that concerned about damp, unlike anything else at this age and price there is no chance of structural damage. Plastic can be repaired easily enough and you would probably want to re upholster it anyway at this age. The drivers window could be expensive although people on here have self repaired.Yep, completely agree. There do appear to be older vans which have been much better cared for.
My thoughts on this are, is the premium brand status with these faults represented in this price?
If so, with some tlc which I'm more than prepared to do, is it going to be a good buy?
Geoff, I looked back at your previous post and just wanted to pick your brains a bit more if that's OK.So is our identical Arto(same year) but does not have those faults.
I suspect yours has had a gentler life GeoffSo is our identical Arto(same year) but does not have those faults.
Afaik that aircon will be maintenance free but you won't be using it much unless you 're on hook up or invest in some decent batteries.Geoff, I looked back at your previous post and just wanted to pick your brains a bit more if that's OK.
How often should the air con unit on the top be serviced? Are there any problems with them?
Finally, I know you originally said you think with a bit of negotiation this could be a good buy, do you still think that?
Thanks Geoff, you've really confirmed what my underlying thoughts. If the aircon isn't standard fit, that is going to add additional weight which is going to reduce our payload.The aircon is not a standard fit and I have never had one.
You are still waiting info on MOT and service.
I would also want it weighed, even before you talk to SVTech
I would do those things before even thinking of driving to view it, because this will establish whether it suits your needs even when everything is working.
As to the list of faults: it indicates to me that it has not been well-cared for and that might lead to other unknown faults coming to light.
Has the garage floor actually been renewed or has it just been covered by the checker-plate?
To my mind it is starting to look as though the odds are stacking up against this one, regardless of price, unless you could get it for £20K.
There will be others around: coincidentally an identical one(2003) has just been sold by the widow of a couple, good friends of us. I do not know the price. She was only selling it to downsize for her needs now, which she has just done.
First concentrate on the weight and possible upgrade in max weight, because it will also inform you about what sort of weight MH you need when looking at any others.
Geoff
Even if the air con was a factory fitted extra it would still have to come out of the payload. Manufacturers usually give the payload in the basic condition before factory fitted extras such as air con, wind out awning and solar.Thanks Geoff, you've really confirmed what my underlying thoughts. If the aircon isn't standard fit, that is going to add additional weight which is going to reduce our payload.
