Is this a micro switch problem? (1 Viewer)
Dec 9, 2017
40
62
I have a mixer tap fitted inside the rear doors of my PVC for an outside shower. When turned to cold no water comes out. When turned to hot it works and it’s hot!
Both the kitchen and bathroom taps are working ok.
And if it is should I fix it myself while the van is still in warranty?
Many thanks,
Paul
Feb 22, 2011
7,053
11,696
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I think the same pump usually works both H & C, so sounds like microswitch is working.
Can you hear the pump start when opening the tap ?
MrPG
Dec 9, 2017
40
62
Just checked and yes I can hear the pump start.
MrPG
Dec 9, 2017
40
62
Yes it’s coming on for hot and cold. This is the first time we’ve used it and I can’t be certain if it was working properly prior. I’ll check the PDI and call the dealer when I’m back next week.
Oct 19, 2014
1,537
4,243
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
@MrPG
There is a break in the wire - the short length that constantly flexes...
When you twist the tap to hot.. the wire connects... twist tuther way - no circuit...
Soon it will not work on either.... but it’s a simple fix...
had experience of that issue many a time on kitchen tap ....
Edit: My first experience was whilst in warranty.. but not worth the journey to get replaced...
When I removed the whole switch and wires... one wire had been trapped and subsequently snapped...
Since then - it’s been just wear n tear - I full time...
I have a job on my to-do list to replace said wires with the more “flexible corded” wire - like those on high end ear/head phones...
Another edit: you should be able to hear the relay clicking on and off... and pump running... if you can then not broken wire... or if you hear it when on hot... and it “clicks off” as you twist... then break in wire...
MrPG
Dec 9, 2017
40
62
Thanks for the replies. I think there could be a kink or air block as when on cold the pump is running and it attempts to dribble out. It doesn’t sound like an air block though. I’ll dig deeper next week.
Shrimp
May 27, 2015
3,212
21,019
Bedfordshire, UK
Hymer B584
Long time
You can look to see if you can see the problem but I wouldn’t do too much or they’ll say you’ve invalidated your warranty!
Oct 19, 2014
1,537
4,243
Lincolnshire, UK
Has cold water ever come out?.. or was this the first occassion used?
Aug 6, 2013
11,265
14,857
Kendal, Cumbria
since 1999
Try sucking with the tap on cold. Check also that water isn't coming out somewhere it shouldn't. Incidentally you can't get an airlock beyond the pump so if it pumps water for one tap it'll pump it for them all.
