Is there an order when adding a tow bar and rear air assist? (1 Viewer)
Oct 10, 2009
883
1,950
Bishop's Stortford
Autotrail Delaware
Since 2011
Took my motorhome to Watling Engineers today to have a tow bar fitted. By the way it is a work of art, but that is not why I am posting. Speaking to the engineer before fitting I mentioned that I was having rear air assist fitted next week by Glide Rite and would that make a difference to his work. He advised that, due to air assist raising the vehicle slightly, it would have been better for that to have been done first so that he could make sure the vehicle level was correct after the work. He did say that it would not be a problem. Has anyone had a problem with levels after air assist has been fitted?
Sep 26, 2013
4,157
5,100
Market Rasen
Since 2003
It definitely will affect the height of the tow ball which can be a problem, I had to fit a drop plate to mine so that the twin axle trailer that I towed to Spain was riding level.
Dec 6, 2011
11,470
25,067
South Wales
Coach built Adria
Surely the hight will depend on the pressure you put into the bags. And that is likely to change as you find the best pressure to suit your needs.
At any point in time
Conal
Oct 10, 2009
883
1,950
Bishop's Stortford
Autotrail Delaware
Since 2011
Phill D From what others have said I think he meant that the rear would be higher as the air assist adds to the height even at the lowest setting. I donā€™t know what he could do to prevent this whilst fitting the tow bar.
Emmit
8,010
17,556
Pilote Explorateur
Jan.2014
The grey matter is corroded but;
Are 'drop plates' legal? In the strictest sense.
I'm not making a criticism but
somewhere in the dark recesses of what used to be called a brain, it recalls that (again in the strictest sense of legality) they became a no-no.
Apr 26, 2015
2,714
6,791
Ottershaw
Hymer S820
First motorhome May 2021
Multi height tow bars are still available, I used to have one on my old Range Rover.
Aug 18, 2014
23,542
131,340
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes the minimum height is 375mm. A drop plate is only any use post 2012 if the drop plate was homologated as an addition to that type of bar ,when the tow bar was homologated.Otherwise it is not legal.
Emmit
8,010
17,556
Pilote Explorateur
Jan.2014
Thank you.
The two examples I understand. However the top one is part of a vehicle system specifically for a certain vehicle, as is the second one.
What I'm referring to is a simple square of metal with holes drilled into it.
I'm thinking that, in these days of conformity etc. such use would negate the conformity on the towing system fitted.
This would not apply to the two examples you have shown.
Feb 19, 2020
1,404
1,552
North Ayrshire
Adria Matrix 670SC
Although Air assist can raise the height of the rear end It's not considerable until you really start to pump them up as you might if you wanted more ground clearance for whatever reason. You generally wouldn't run with them at those sorts of pressure as the ride would be too harsh. Adding air as you load the van means the level stays about the same.
43,207
48,833
The towball center should be 17 inches above ground level.
All commercially manufactured trailers /caravans etc are built to this level.
Ridgeway
3,626
6,055
Lausanne
NiBi Arto 85E
I added rear air after i had my tow bracket installed and i didn't notice any major difference in height. My tow bracket (Sawiko) is adjustable in height so i could lower it although the steps are actually pretty big.
I did measure my trailers hitch height and asked the installer to match that which they did.
Apr 26, 2015
2,714
6,791
Ottershaw
Hymer S820
I just wanted to illustrate that approved variable height tow bars are available, the OP would need to find the correct one for his motorhome. I would have thought that pretty much all tow bars are vehicle specific.
Apr 12, 2012
1,679
6,350
N/E Lincs
Autosleeper Rienza
as above
The breakdown vans we used had air assist fitted to enable us to adjust the ride hight depending on what trailer or A frame we used. It was a simple job to adjust the pressure and helped with keeping the trailers stable.
