Is my flexi solar panel goosed?
Spain
Adria Sonic 700i SL
I have a 100w (my estimate based on size) flexi solar panel on the roof, which at a guess I would say is 4 years old. (On the van when I got it ) it is wired through a CBE PRS300 controller with a PT642 test panel also connected.
The test panel is showing voltage in the batteries at 13v, but not showing any amps coming from the solar
I have been on the roof and used my multi meter and tested voltage from the panel at 15-16 volts, but again no amps at the panel ( I unplugged on the roof and just tested at the connection of the panel)
Have I missed anything, or is the panel goosed?
Thanks in advance
Bump
Hope you get some answers.
I had two on my van, (same flexi ones) and when I tested the output there was nothing there at all. Never had a solar panel go wrong before until this and I've had them on vans for 15+ years. Therefore I never replaced them with flexi ones. Also, I have had to leave the flexi ones on the roof as they are next to impossible to get off.
It might just be winter with low sun and lots of cloud. By this time of year your panels would work better stuck vertically on the side of the van than on the roof.
He's in Spain according to his avatar so I don't think that's the problem.
I think the panels are goosed not many Flexy panels last that long.
It's always difficult to say in winter, every year we have had the feeling the solar panels are not working as they should, in fact sometimes very disappointing compared with in the summer months, once the sun starts rising in the spring everyone will post how many amps they are getting, the days getting longer less demand on your batteries and it's I love my solar panels all this free electric. 😉
Even here in Spain we suffer, they work but not as well, when we had the caravan on a winter pitch I had a 100w panel and moved it around leaning against the a frame following the sun 😉 worked a treat, if it was laying flat on the roof I probably wouldn't have bothered using it. 😎 Bob.
Yeah would agree but I am on the sunny Costa Blanca and still plenty of sun ☀️ around , so am drawing a conclusion that they are knacked! 🥲🥲
They do come off Paul. I had 2 one failed, peeled it off slowly stuck another one on, that lasted about 18 months so then replaced it with 2 rigid ones. There was some adhesive left but the new ones covered it. Think the CIGs ones are better because no glass to break.
Think I have been lucky, managed to get it off today and after a bit of cleaning with silicone remover the roof is as good as new - now for a new rigid panel
Thanks in advance
I have spoken to a number of Motorhomers who have had the flexi solar panels, and all say the same thing they just don’t last, the last one I spoke to very recently in Portugal said his first 2 flexis lasted 2 years the next 2 lasted slightly longer, it seems this is a common problem especially on panel vans as there is no air gap under the panel to aid efficiency and help keep the panel cool, compounded by the fact I think that in hot sunny weather especially abroad the roof of a panel van gets too hot to touch on occasions and I feel that it’s this that causes the premature failure of flexi panels, I’ve never had a problem with rigid glass solar panels, but there’s the added weight of them over the flexis......Just sayin....
