- Aug 24, 2022
- 274
- 763
- Autocruise Gleneagle
- I'm a newbie had a wobbly box when adam was a lad
Hi funsters found this MH advertised at a dealer but on checking the MOT history it expired 28 June 2022 with these advisories do you think worth considering if the dealer where to put them right
2005 Auto cruise Wentworth
Mileage
34,200 miles
MOT test number
9610 2785 8998
Monitor and repair if necessary (advisories):
• Offside Front chassis corroded and holed by radiator
support cross-member
• Subframe mounting prescribed area is corroded but not
considered excessive offside and nearside front around
jacking points (5.3.6 (a) (i))
• front radiator support cross-member corroding
• offside and nearside rear suspension add on air bag
support plates corroded and weak
Check MOT history (https://www.gov.uk/check-mot-history)
This vehicle's MOT has expired
You can be fined up to £1000 for driving without a valid MOT
This vehicle may be MOT exempt, for more information refer to
YN05DYG
PEUGEOT BOXER
MOT expired on
28 June 2022
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test
certificate
PEUGEOT BOXER - Check MOT history Broken Link Removed
1 of 8 14/09/2022, 23:44
• Front Upper Suspension component mounting
prescribed area is corroded but not considered
excessive inner wings offside and nearside (5.3.6 (a) (i))
Mileage
34,200 miles
MOT test number
9610 2785 8998
YN05DYG
PEUGEOT BOXER
MOT expired on
28 June 2022
MOT history
certificate
