Hi , wondering if it is possible to change from one gas bottle to another from within the cab. I do have a automatic gas changer valve in my shed, but would like to know when one tank has emptied. Don’t know if such a device exists or not.
That sounds easy peasy, thats why I would send the wife out to do it...well shes gotta learn about all these Techie things and practice makes perfect eh?Takes 15 seconds to open the gas locker door and look at the auto change-over valve to see which bottle it's using.
And then before the second bottle runs out you go and remove the first to replace or refill it... ... You're still going to have to open the locker door so why not just have a look.Truma C Remote, fits onto the dual changeover regulator and gives you an indication inside the van when the bottle changes over.
something like this:Hi , wondering if it is possible to change from one gas bottle to another from within the cab. I do have a automatic gas changer valve in my shed, but would like to know when one tank has emptied. Don’t know if such a device exists or not.
No not if you have refillables?And then before the second bottle runs out you go and remove the first to replace or refill it... ... You're still going to have to open the locker door so why not just have a look.
Because it's much easier and convenient to have it pop up on the display insideAnd then before the second bottle runs out you go and remove the first to replace or refill it... ... You're still going to have to open the locker door so why not just have a look.
I know when it's changed over so I know I have at least 15 days (less in winter) to get to a filling station.And then before the second bottle runs out you go and remove the first to replace or refill it... ... You're still going to have to open the locker door so why not just have a look.
Doesn’t say Duo C on ours I fear.Truma Duo C plus auto changeover.?
Truma remote indicator UI with cable for DuoControl CS, integrated anti ice
Remote gas indicator DuoControl CS Heating and cooling also during the cruise.The Truma remote display shows the operating status of the gas cylinder in the living area. The IceEX controller heating prevents the gas pressure controller from freezing during winter operation with high gas...www.cara-tech-24.eu
you may already have duo C on Frankia.
Is that inline filters you have there Lenny if so where did you get them please?
Not if you have a PVC with a scooter on the back. It can be a faff.Takes 15 seconds to open the gas locker door and look at the auto change-over valve to see which bottle it's using.
So where can I purchase this item from please.
Need to make sure your regulator is suitable, otherwise a new regulator is around £180.So where can I purchase this item from please.
Are the gauges in the cab ?I have gauges on my two 11kg Alugas. When one runs low I manually turn over to the other. I dont let it run right out so dont need to changeover at inconvenient times.
Will deal with bottle and gauges first, before we move on to the next topic.How about interior lights that come on when you clap?
Or a robotic self emptying cassette?
Or a fridge that automatically restocks itself with beer and then slides a cold one to you along a rail to the captain's chair.
