Sorry don’t see why you need the inverter, straight from usb should work.
USB is only 5v and typically 1 amp (5w) so charging a laptop would take about 10 times longer than using a 240/20v 2.5amp charger12v to 240v to 12v simply doesn’t make sense, is very inefficient and not good for your batteries
Surely its better to go direct to usb i’d have thought
12V to 5V USB still involves electronics and changing the voltage, cheaper devices may not be properly shielded or producing a clean output. Electronics used in moving vehicles not only need CE marks but should also have an E mark, to show that they do not give off any interference that might affect the vehicle systems. Not so important when parked up but shows that electronic devices can interfere with each other.12v to 240v to 12v simply doesn’t make sense, is very inefficient and not good for your batteries
Yes but op is talking iPhone and iPad both charge fine on 2.1amp usbUSB is only 5v and typically 1 amp (5w) so charging a laptop would take about 10 times longer than using a 240/20v 2.5amp charger
The OP is talking about the ipad and iPhone charging. It should go straight to 12v powered usb. That way there is no interference from a dirty AC.USB is only 5v and typically 1 amp (5w) so charging a laptop would take about 10 times longer than using a 240/20v 2.5amp charger
Ah yes - see that now, although I gave up with iphones and only just grudge an ipad after buying so many USB charging cables (of many varying prices) that didn't work.Yes but op is talking iPhone and iPad both charge fine on 2.1amp usb
I get that with my Samsung lap top when it's charging on mains but only since I bought a replica charging lead.BUSBY.It’s the first time I’ve been using the inverter to charge the iPad and iPhone. When I do, the touch screen doesn’t work or the fingerprint ID.
Is this usual?
I got to the stage of being locked out of the iPad for 15 minutes.
Take the charge lead out and everything is fine.
buy cheap buy twice or many times in your caseAh yes - see that now, although I gave up with iphones and only just grudge an ipad after buying so many USB charging cables (of many varying prices) that didn't work.
you have completely missed my point which was the up conversion of a 12v voltage to 240v then down converting it back to 12v.12V to 5V USB still involves electronics and changing the voltage, cheaper devices may not be properly shielded or producing a clean output. Electronics used in moving vehicles not only need CE marks but should also have an E mark, to show that they do not give off any interference that might affect the vehicle systems. Not so important when parked up but shows that electronic devices can interfere with each other.
But he is not taking it to 12V, he needs 5V for charging iPhones and iPads. This also involves voltage conversion and power wastage. Many of these plug in 12V USB devices are crude and achieve the voltage drop by turning it into heat, which is why they get hot. However I agree that turning 12V into 230V and then back to 12V is not generally efficient.you have completely missed my point which was the up conversion of a 12v voltage to 240v then down converting it back to 12v.
It simply doesn’t make sense, is not electrically efficient and certainly not necessary in the OP’s case
It will be a voltage regulated power supply 110 or 230v input.I had a similar issue with a laptop, the touch pad kept cutting out when it was plugged into the cheapo invertor.
I'm not sure why though. Computer power supplies and phone chargers use switch mode power supplies. They really don't care about the quality of the waves coming in. Our house had an issue with the local substation where once of the phases had completely failed. All the incandescent lightbulbs went dim and the microwave and vacuum were not happy. But my laptop carried on charging. The substation caught fire a few hours later...
Unfortunately, they weren't all cheap that didn't work, £22.99 was the dearest not to work and a 99p from China one is charging the iPad as I typebuy cheap buy twice or many times in your case
I wouldn't get carried away with the efficiency argument - in fact, it's probably better to use an inverter.you have completely missed my point which was the up conversion of a 12v voltage to 240v then down converting it back to 12v.
Also why would you want to use an inverter and batteries for let’s say 2-4 hours to charge an ipad, your flattening your leisure batteries when it’s simply not necessary
