Invertors v Battery (1 Viewer)
May 6, 2010
547
638
Doncaster
April 2010
With these Invertors installed (8000w each) how long will my 110ah leisure battery last running the wife's hairdryer ??
:wasntme:
Jaws
23,827
72,281
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I know the question is tongue in cheek but actually the answer is....:D2
It depends on what the hair dryer is rated at !
The inverters will draw very little current on their own, and being so big are probably pretty efficient too :)
Localdave
73
29
Devon
Compass Suntor 400RL
Since 2016
Just showed the wife,she wants the same, I laughed out loud
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
On high speed setting and medium heat 20 minutes tops
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Personall i think you are just showing off and have gone right OTT
An 80ah battery would dry your wife's hair
= 79. 76 AHrs
manda3000gt
May 6, 2010
547
638
Doncaster
April 2010
I
What is that a pop stars RV?
It's on board the new Everton FC football coach that we valeted on Tuesday, we have the new Liverpool FC one to do before the end of the month with even more equipment on board
Mar 24, 2010
1,072
765
stoke on trent
relay lwb pvc
6 years
Sorry to jump the thread but I have a split charge system/80a solar and 2x 110a LB.I have a 600 inverter with which I intend charging off grid a laptop and a 36v/10ah elec bike battery (preferably plugged in while driving van) Will it be possible as I go on aires etc?
Minxy
32,621
66,433
E Yorks
Carthago Compactline
Yes you can.
We had a 75w solar panel on previous PVC and 2 x 95a batteries and use to do as you are planning, I made a cradle out of a motorhome stacking cup holder which I fastened up under the dash on the passenger side into which the inverter was fitted and strapped to keep it in place, but so that it could be removed and used elsewhere if necessary then on the cab floor underneath it I fastened some straps which held the battery being charged in place so it could be done on the move safely, the 12v ciggy lead from the inverter was then simply plugged into the 180w outlet on the dash.
Oh, forgot to say, we don't do campsites, just aires or wild camp for 7 weeks twice a year!
Mar 24, 2010
1,072
765
stoke on trent
relay lwb pvc
6 years
Yes you can.
So you think it should be successful to charge Leccy bike battery?
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
36v !?!?! From 12v !?!?!
Explain, some techno wizard please !!
As we are considering lucky bikes.
Mitch.
canopus
6,127
10,237
rural Lincolnshire
Carado CV640 Pro
Since 2010
The bikes battery charger is plugged into a 13 Amp mains socket in the vehicle in the same way you would at home. The mains sockets within the vehicle are driven by the on board inverter/s which convert DC power to AC power.
Minxy
32,621
66,433
E Yorks
Yes, we've done it without a problem.
Mitch.
36v is just the size of the battery itself, it doesn't mean it is re-charged at 36v.
haganap
12,754
26,393
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I
That explains it then, it's the hair drying requirements for all the footballers along with the ceramic tongs...
funflair
19,287
30,053
Guisborough
MORELO palace
since 2012
But the size of a battery is measured in A/Hours.
36 volts means 3 times a 12 volt battery surely ( yes I know your name is Mel) ;)
Mitch.
Correct, but you need to be carefull with calculations based on amps when the voltage is different, if you worked in watts/hour as in ah x volts it could be less confusing.
Martin
Minxy
32,621
66,433
E Yorks
Mitch.
Yes my name is Mel ... ????
I was just trying to make it clear that it doesn't mean it is drawing 36v ...
Jan 9, 2017
185
706
Luton
Fiat Ducato
Newbie
What can they possibly have to need 32kWh of power.....or do they run the grounds floodlighting off the coach.
I would have thought they would have been better if with an onboard genny that you get on small boats
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
"Many a Truth,Quoted in Jest".:D Bunch `O, Nancy Boys, Now, Rugby___!. They dont need Hair-dryers!
