Oh yes it did........
You probably have an ad blocker running - it will prevent Amazon ads showing up. I can see them in your post as I don't have one.Oh no it didn't...
Amazon
Soofotoo 500 Watt (Peak 1000Watt) Pure Sine Wave Car Power Inverter DC 12V to AC 230V Voltage Converter with 5V 2000mA USB Port
Do you just plug this into your 12 volt socket (cigar lighter)HI
It was this one:
Amazon product ASIN B01MYXVJTF
I did think it had started playing up earlier this year, but I was wrong (I hadn't wired my batteries correctly).
Its working fine, charges my ebikes and runs my wife's hairdryer (400w) no problem.
No, it draws too many amps at full power even though the pic shows a cig plug. .Do you just plug this into your 12 volt socket (cigar lighter)
Thanks papa John, so how do you wire it inNo, it draws too many amps at full power.
Should be wired directly to the battery with a 50a fuse in the positive wire..... But not using that wet string that's provided with it, its not heavy enough to take 44 amps looking at the picture.Thanks papa John, so how do you wire it in
