How were you powering the old inverter, from the leisure batteries?I need to buy an inverter to power my onboard cab battery charger. The old one has nothing on it ie name model or power. Any suggestions please? Links would be good.
Two 95amhHow were you powering the old inverter, from the leisure batteries?
What amp/hrs are your leisure batteries?
Do you have solar?
Are you on hookup?
There are several ways to keep your cab battery topped up, if you can answer the above and we should be able to give more specific advice.
Ed
Best wishes because I think the key point here is in your second line.Right I will start at the beginning.
I know very little about electrics.
When I bought the van I was told when you are on hup you need to flick this switch. Which was on the inverter. Which I have been doing. I assumed that it was to keep the cab battery charged. Had no problems with cab battery. The leisure batteries are charged by the single solar panel. Checking around the van the other day I found that cab battery was down. Checked to see if I had forgotten to flick the switch on the inverter. It was switched on but no power light so I checked all the fuses, all ok.
To me it pointed to the inverter so I assumed that the inverter powered a hidden charger. Am I wrong?
At the moment I have a trickle charger hooked up to cab battery. But it means having the cab floor up and will not be practical when on site for a week. SWMBO will not wild camp.
From reading posts on here my SP will not be powerful enough during the winter to keep the cab battery charged if it is connected to solar pane. Not sure how to check whether it is or not. Wished I lived next door to Lenny HB
I am open to advise indeed I welcome it.
I have bought one of these.
Ideal they work well and will keep your cab battery topped up. I use one.
