Intelsat 907 no signal found (1 Viewer)
DJP
86
21
Somewhere in Europe
I have an 85cm Oyster dish with auto skew LNB and an Icecrypt box plus SKY HD box
With the dish pointing to Astra 2 I can pick up a few SKY broadcast programmes.
If I point the dish at Intelsat 907 which is programmed into the Oyster system, the Icecrypt box says no signal or no satellite found. It doesn't matter if I do the auto configuration or do a manual search for Intelsat 907.
Any ideas would be greatly appreciated/
Thanks in advance.
Sep 10, 2017
711
830
North Brum
Silly question but do you have a feed from the LNB going into the Icecrypt, and if so have you tried swopping them over to be sure the both sides of the LNB are working?
DJP
DJP
86
21
Somewhere in Europe
There is currently only one feed connected to a switcher box which either sends the feed to the SKY box or the Icecrypt box. It has always been this way and has worked before (last winter) with the same set up and on the same campsite, just on a different pitch.
I am assuming the LNB is OK as I can pick up the SKY channels?
Sep 10, 2017
711
830
North Brum
Ok so bypass the switch and see what happens, check it on both receivers. I presume no obstacle for "line of sight" ? Also confirm LNB power on, Universal LNB etc is still set on Icecrypt.
