Intelligent Charger Recommdations (1 Viewer)
jo10000_6
249
137
South Yorkshire
Hymer B544 Classic
Jan 2018
Hi All
I'm looking for a reasonable priced multi stage intelligent charger that has been tried and approved by the funster community.
I currently have a Torq multistage intelligent one from B and Q and I just get the feeling it's struggling with the my leisure battery.
I want to be comfortable to leave on a slow deep re-charge and be comfortable I'm not cooking it.
Jo
Jan 28, 2017
150
87
New Zealand
Hymer S520
newbie
I have been using a Genius 7200 on my AGM batteries and am impressed with it. It came in a 240 volt model and even does lithium batteries. Only 7.5 amps and 265ah limit. Oh and it does 24volt also.
6,872
7,991
Manchester
A class Hymer
Since the 80s
It depends on exactly what type of battery you want to recharge. For classic lead-acid wet-cell batteries, open or sealed, any automatic 3-stage charger will do the job. For gel or AGM types, a slightly different charging cycle is required, and many modern chargers have gel and/or AGM settings.
For wet-cell lead-acid batteries, the charging current (amps) should be limited to no more than a fifth of the battery charge capacity in amp-hours. For example, for a 100Ah battery, keep the charging current to 20 amps or less.
There's no minimum charge current. A lower current charger will fill the battery just as effectively, but will simply take longer. And once it goes into trickle charge/maintenance mode, it is just the same as a higher current charger.
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
We've got a CTEK one and it seems to do the job. As mentioned, you just need to ensure whatever model you choose is suited to your batteries - or batteries you might change to in the future.
