Insulation curtain between cab and hab (1 Viewer)
Sep 16, 2010
2,951
2,771
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Looking for the above to fit our Tracker
2 berth with over-cab storage, so that we can shut the cold cab off from the habitation part.
Anyone done this or found one on-line ?
Or must we make one our selves ?
Thanks in anticipation.
Mitch
Apr 3, 2018
3,220
8,748
PVC
1995-2004 & 2017》
Mitch
We done on 2 of our mohos in past.
Not a kit.. sourced an oppropriate rail from B&Q and Mrs Poppycamper run up a curtain to fit..... cheap as chips and did the job.
Sep 3, 2012
7,059
23,444
Cheshire
C Class Elddis 175
8+ years
We have one built in on our van ,it makes a big difference. On a previous van we used the old fashioned curtain wire,plastic coated ones, and put on some home made curtains, it made a big difference to temps and was a bit more. " homely" .
Aug 12, 2020
1,368
2,312
Edinburgh
Accordo 120
Sept 2019
I understand that you can buy cab curtains specifically for the base vehicle e.g. Boxer.
I had the same issue in that I felt that the Accordo cab was quite gloomy (and cold) of a winters night. My solution was to buy an expanding curtain rail (or you could buy a fixed length curtain rail and cut it to size) and a pair of thermal curtain liners (only needed one and got it cut to to size). I fixed the curtain rail using double sided tape at intervals along the length and screws at the end plates. I opted for the thermal liner as I didn't want to put too much weight on the rail. The idea works a treat and keeps the warmth in the Hab area.
The Accordo came with thermal cab blinds, which I still use. I've also bought a set of silver screens to help with the heat loss and made a few "Silver Screen" type roof window heat reflectors.
Best wishes, Dram
tonka
10,673
21,035
Cannock, Staffs
A class Burstner 800
Since 2000
Done it on several vans in the past.
Length of curtain wire from Wilko or eBay. Just use up any old curtains or a sheet. Even a thin material makes a big difference.
Minxy
31,958
63,566
E Yorks
Carthago Compactline
Expanding tensioned shower rail with thermal curtains - once cut to length don't need stitching - the pole just jams between side walls and can be removed if need be. I've used the same thing in the past for a curtain across the hab door.
Feb 16, 2020
1,872
2,602
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Same here homespun 40mm timber rail sits in cups, so removable in seconds. Insulated 2 piece curtains, with popper studs in the middle. Really handy for a quick pull in to get 40 winks , also blots out sound as well.
Mike.
Jan 22, 2013
1,198
51,732
London SE
A class Adria vision I707
since 1971
Used an old quilted duvet, put poppers along the side of the front drop down bed, we use for both heat retaining in winter and as Gus said also keeps the cold air at the front in summer, Duvet cost a fiver from the charity shop and poppers from eBay,
