- Nov 1, 2021
- 161
- 119
- Burstner IXEO Time
- Complete newbie
Hi all, I'm hoping someone can put me right on the correct cable size and fuses to use when installing USB ports.
I have identified a 12v supply on my EBL 119 from a outlet (Spare 6) on Block 8 and plan to install 2 double 2.1A USB sockets. According to the Schaudt electrical diagram the maximum fuse size should be 15Amp which I have fitted. I'm hoping to run a twin cable and connect both ports. I'm assuming that if all ports are in use the maximum power will be 8.4 amp so the 15amp fuse more than adequate - or should I make it 10amp? Also planing to use either 1.5 or 2.5mm2 cable. Also do I require further fuses on the positives to both ports and if so what size? Doing the install no problem but as I'm obviously no electrician I want to make sure that whatever I do is correct and safe. Many thanks.
