RE-.... the sides don’t sit fully flush against my motorhome side so the wind can buffer through the small gap and it can drip rain in.I have a Kampa Air 400xxl and it’s been fantastic so far.
As mentioned earlier, it’s heavy and weighs in region of 28-30kg including everything that comes with it.
We took ours down last week during near gale force winds as the wind had blown the front and roof inwards so much that we could hardly open the Hab door. That said, I just pushed it back outwards. Very flexible and forgiving but if you are to use it in strong winds, I suggest ditching the standard pegs (the wind lifted all of our pegs) and invest in some Delta pegs (yellow right angle pegs).
The downsides:
It’s heavy - you thread it through the awning channel on your awning cassette. - that’s some weight on your awning cassette so be careful when winding it out to thread it through as it’s heavy.
Second, the sides don’t sit fully flush against my motorhome side so wind can buffer through the small gap and it can drip rain in.
I had an Omni Safari room with sides prior to the Kampa and between the two I would go for the Kampa every time. The build quality is very good
Have you thought about having your existing driveaway altered so that the 'tunnel' is removable if necessary? Alternatively sew an extra piping strip on where the tunnel joins the awning (on the outside!) then you can just roll the tunnel part up 'inside' and use the new piping.Recommend the Kampa range myself, we have the 330 XL Air Pro Driveaway Version and are going to buy the same without the Driveaway ext as we cannot use drive away on CCC sites as pitches to small, then were covered on both club sites.
You need to make sure you buy the correct size S. L. XL. XXL some sellers on the usual auction sites are selling because of the wrong sizes purchased so you might be lucky and grab a bargain
Regards Darren
One thing to check carefully is the angle of the tunnel on driveaway awnings and the roof angle on non-driveaway ones as this is what could prevent you opening the hab door. I prefer a poled awning myself as I think they are more 'rigid' and also as they split into 2 sets of parts, ie poles and fabric, some go in the same bag but most are in 2 separate ones so each is therefore lighter and can be stowed more easily.Can anyone help with advice on purchasing a good inflatable Awning for our Bailey Autograph 79-4i 2017 MODEL.
Any help much appreciated. AK.
Now that sounds like a planHave you thought about having your existing driveaway altered so that the 'tunnel' is removable if necessary? Alternatively, sew an extra piping strip on where the tunnel joins the awning (on the outside!) then you can just roll the tunnel part up 'inside' and use the new piping.
That’s brilliant. Thank you. I didn’t know about these and just Googled them with a video and it’s exactly what I need. Thank youRE-.... the sides don’t sit fully flush against my motorhome side so the wind can buffer through the small gap and it can drip rain in.
Get yourself some limpets to secure to the side of the Moho Gavlad about £20 for 8 work treat on mine
Any suggestions for a normal awning, that doesn’t have limpet holes?That’s brilliant. Thank you. I didn’t know about these and just Googled them with a video and it’s exactly what I need. Thank you
But I have quite a few friends with MH and none of them have an awning neither do we. We seldom stay more than one night very rare more than 2 so putting up an awning is not going to be worth it we don't even fence off the edge of the pitch with a windbreak!If you think the amount for sale tells you people buy them and don’t use them just count how many vans are for sale in the classified.
Buy the limpet hole cutter, think their around £12 on Amazon, some early Kampa models came without pre/cut holes so people had to buy these to fit the limpetsAny suggestions for a normal awning, that doesn’t have limpet holes?
It’s a case of each to their own Wino, we use sites and most minimum stays are a week or two we use ours a lotBut I have quite a few friends with MH and none of them have an awning neither do we. We seldom stay more than one night very rare more than 2 so putting up an awning is not going to be worth it we don't even fence off the edge of the pitch with a windbreak!
It would be interesting how many do carry an awning maybe I'm strange that way I know I'm strange in other ways!
Thats just my point and as you say each to their own although if I wanted to do that I would probably get a caravan.It’s a case of each to their own Wino, we use sites and most minimum stays are a week or two we use ours a lot
No need for Caravan my awning is a driveway one so not restricted to stay on site either.Thats just my point and as you say each to their own although if I wanted to do that I would probably get a caravan.
But much easier parking and exploring from a base with a car. We did it for a few years when the kids were young. The big advantage in a motorhome for me is the ability to be self sufficient off grid and pitch in 5 minutes it outweighs less space increased cost and higher maintenance. If I was going to pitch a week or two on sites I couldn't see the point!No need for Caravan my awning is a driveway one so not restricted to stay on site either.
More power to you WinoBut much easier parking and exploring from a base with a car. We did it for a few years when the kids were young. The big advantage in a motorhome for me is the ability to be self sufficient off grid and pitch in 5 minutes it outweighs less space increased cost and higher maintenance. If I was going to pitch a week or two on sites I couldn't see the point!
