iNET system for Truma heating. (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Anyone got one of these systems? If so, does it only work whilst you’re within Bluetooth range of the van?
wingman
wingman
1,217
3,333
Romford, Essex
It uses an app that send sms messages to it when you are away from the van.
Seems awful lot of money to turn the heating on when the controllers has a timer anyway.
Thanks Lenny.
These are fitted to some low to mid-range MH’s now; one of which I’ve been looking at.
So; effectively, the app sends a text to the van unit and tells it to turn on the heat or hot water? Is that what you’re saying?
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Agree, I think the van is more likely to be "iNet-ready" than have the module (which is easy to fit). It will need a SIM card if you want to use it away from the van, else uses bluetooth. It can control more than just heating, if the right kit is added, and even report the amount of gas left in your bottles. Another toy for those that have everything else?
wingman
wingman
1,217
3,333
Romford, Essex
O I C, it’s a play on words then. It’s a bit like a TV when it said ‘HD Ready’ when it wasn’t actually an HDTV until it was fed the right signal.
Soooo, unless you add (and pay for) another box of tricks, the iNET control panel is just a bog standard digital controller that you set manually :rolleyes:
Christoph
554
758
Lytham
VW California
Since 2014
Ours is iNet ready but as you can set the timer for water and heating we've never felt the need to fit the £200 box + fitting. Just set the timer before you leave. You will still rerun to a cosy van.
53,426
149,962
My thoughts exactly, nothing to induce me to buy the controller.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
My MH CP panel is iNet ready and I have often thought about adding the iNet box. (y) This would allow me to turn on the water and or heating before I need to leave the storage area without the need to keep the heating and water on every day on a timer.(y) Often we are delayed in getting back to the MH when out for a walk - poor planning I know, but the iNet system would allow us to switch on as and when we pleased. :D2 It is much more than just a timer!! and there are more features being added, like the gas level indicator for those with "Calor" bottles - saves returning a bottle too early. ;) The only thing that has stopped me so far is the price. Great bit of kit, but the inconvenience of not having one far outweighs the outlay. :cautious:
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
The standard timer is a simple 24hour clock. Handy while you're using the van but no good for setting for a future date, even if you knew when that would be. iNet would work if you want to control or measure from a distance at any time that you have yet to decide.
I don't yet have a requirement for that.
Christoph
554
758
Lytham
VW California
Since 2014
I'm not knocking the principle or the technology. I'm sure many people will see the value and benefits depending on circumstances. It's just not for us at the moment.
Dare_Devil_Dennis
296
199
Derby
I was a bit outraged when I found out the iNet box was an "extra" as advised by the swift dealer I bought my first motorhome from. I consequently fired off a vitriolic email to Sargent Electrical to suggest that they, as designers of the electrical systems in the Swift range were using the Truma iNet system as "ransom-ware" and they should be ashamed as they could easily have designed that functionality into their EC600 control panel which incorporates a sim card, tracker system and remote control of lights etc through the Swift APP.
Rather embarrassingly, they told me that was exactly what they had done and there was no need for the iNet box in the Swift range of motorhomes. It turns out that mine didn't work because the dealer had not configured the controller properly. Sargent went on-line for me and set it all up properly FOC!
Unfortunately, the EC500 does not do the same so us Autosleepers customers must do with less or pay more.
Interetingly, the 2018 range that have Truma air con needs the inet box to control the A/C through the CP panel so they come installed. When I bought my 2017 Stanton, I squeezed the deal to include an Inet box in case I fitted the A/C later. I have not bothered yet with a sim card, so I just use it with bluetooth. The Truma APP has a neat levelling function that works with the phone. I think a free sim card will do the job. I think they only need one chargeable call every six months to keep them active.
Dare_Devil_Dennis
296
199
Derby
Yes, but not cheap and no real benefit. The CP controller is not that intuitive (unless I have less intuition than most). The dual dial set up is simple, the CP controller is not. You could add a timer the the Dial set up if you wanted to.
Some forum participant was advised by Truma not to bother upgrading to CP controller.
53,426
149,962
Can the CP controller replace the dual dial set up ?
Yes did on my last van, early C4 or C6 Combi's need a replacement PCB Truma do a kit for about £400. If your boiler is CP ready you just need the controller around £250.
Well worth doing as the CP Plus controls the heater fan so much better and keeps the van at a much more even temperature. Due to trade contacts I didn't pay anything like that for mine but after finding out the improvement I think I would had paid the 250 if needed.
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Can't add too much to @Lenny HB post above. I had mine done by dealer FoC as an upgrade.(y) Very good benefits of easier control, set temp as you like not just "about" and you can off set the Room temp stat so if you find your stat is over the hab door and colder than the rest of the MH, you don't have to sit in a sweat box until the room stat gets to the same temp as the room. My stat is over the rear door and beside the open vent, so there is quite often a 4 deg difference between the rear and the sitting area which is far too hot for us. plus the bathroom gets like a sauna.:oops:
Stonemags76
1,280
3,994
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
Hi we’ve got the iNet on our new (to us) Warwick Duo. I’ve easily set up the Bluetooth control via the app, & I ordered a PAYG mini sim from Three, and put it in. Now Three are saying the sim needs to be activated before I can top it up. Can it activate via the iNet box does anyone know? It’s a mini sim, & we have iPhones, so can’t just put it in a phone to activate it.
53,426
149,962
Providing your iPhone is unlocked don't see why you can't put the SIM in to activate it.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Apparently Alde, unknown to me in the same group as Truma, have discontinued their smart control and it will be replaced by iNet, they just don't know when.
RichyWHL
8
I've got one, didn't realise it was an extra when the van was kitted out, otherwise I wouldn't have bothered.
Tude
255
211
Bolton
Autotrail Delaware
Thanks Lenny.
These are fitted to motorhomes if all prices even over £100k !!!!
Tude
255
211
Bolton
Autotrail Delaware
I net ready panels still need a inet box fitted with a SIM card. Then your smart phone can connect to it .as long as your panel is on you can communicate with your fone IE turn the heating on or turn the heating up .
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Not sure I would want to leave the gas turned on whilst in storage for a while just for the convenience of being able to warm the vehicle up and turn on the hot water.
Tude
255
211
Bolton
Autotrail Delaware
I think the panel
