Indicator on the blink (2 Viewers)
Oct 21, 2017
582
1,676
This might not be the right forum for this post, who knows ?
My moho indicator has an intermittent fault.
If I use it as a motorway overtake , 5 blinks ,it works perfectly ok. If I click it on to run continuously it speeds up and the indicators don’t actually blink!
Any ideas / solutions ?
Lenny HB
53,415
149,901
On the coast in West Sussex
Hymer B678 DL
Sounds like a job for your nearest Fiat dealer, not worth messing about yourself on a new van.
Never heard of that happening before, if it was the flasher module you would expect it to do it on 5 flash sequence.
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
Is it both sides or just one side and do the hazards lights function normally ?
Oct 1, 2013
7,511
19,937
Lanzarote
Nil by mouth
Lots
Paddy "are my indicators working ?"
Murphy, "yes, no, yes, no, yes, no, yes, no etc........
Tigertom
Oct 21, 2017
582
1,676
It happens on just the one side and if I put the hazards on.
Nov 7, 2015
497
469
Newport, Shropshire
Possibly a bad connection on one of the bulb holders but that normally makes one of the bulbs not light up very bright or not at all, also could be a faulty hazard switch or the indicator switch itself.
Check what you can yourself then it’s time for an auto electrician, good luck.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Check the lamp EARTHING, Most if not all new vehicles are CANBUS. The controls rely on such small currents that ANY earth fault causes issues.
Jun 18, 2012
317
531
Preston
Grandad's Camper-CPC
Since 2012
Your best solution would be to buy some of those BMW indicators.
They aren't cheap, but they never go on the blink!
Stretto Boy
1,503
306,424
Leicestershire
Since 2011
I bought l BMW last Saturday and my indicators still work:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
CANBUS influence stops at the rear lighting control unit. Wiring from there to the lamps themselves is conventional as are the bulbs & connections. The control unit does however monitor bulb current so a faulty connection in a light unit, or a duff bulb, will result in a dashboard indication. Whether or not the vehicle uses CANBUS a fault affecting both front and rear has to be caused by something common to both. First in line is the column switch which is simple to check if pre-CANBUS and not too tricky even if CANBUS. I would guess that fusing pre-CANBUS would affect both sides so again my first check would be column switch and connectors.
Tigertom
Oct 21, 2017
582
1,676
Blinking happy now, I’ve sorted it out.
I should have had a proper look in the first place, loose connection was the problem. Thank god it wasn’t a canbus thing, I’m not sure what they are. Thanks to all who responded.
