Hi all
I am applying to get my payload increased on the MH - apparently it’s a just paper process . Is anyone aware of any drawbacks ?
I must have been lucky then. Did it myself, sent off the form with accompanying letter from manufacturer saying it could be uprated to x and was surprised how quickly got the V5 back (with part refund of road tax). I'm not blessed with much patience so it couldn't have been difficult. Used the saving to buy something else for the MH
If it's just a paper excercise, then you probably won't gain much in overall pay load.
That's about the only thing they're good at, losing mail.Phoned them after being shunted through several departments was informed none of my original documentation was to be found and to resubmit all paperwork again
Yes, I emailed the manufacturer with model, chassis number etc (all info I could think of to identify it for their records) and they wrote back very promptly confirming that that vehicle could be upgraded to xkg without the need for modification. All manufacturers must be used to providing the info and the letter they sent was accepted without question by the DVLAAJM2 - Did you ask the manufacturer specifically for the letter you are referring to or was it another / standard supplied document? ie. what did the doc from the manufacturer say / cover?
The permissible axle weights will remain the same. All it allows you to do, is shift the load around to optimise the loads on each axle.
That’s not the case at all.
We increased our GVW by 300Kg all gained by an uprate of 2 x 150Kg on the rear axles.
Ian
it very much depends on the chassis weights already applied by the converter. example
front 1500kg Max 1850kgs
rear 2000kgs max 2000kgs
so you could paperwork upgrade to 3850kgs but the rear axle max would remain the same so any additional weight is over the front axle.
if the converter has down plated the rear axle also then you will have an increase over the rear.
hi Phil D its a carioca 705 and looking at the v5 it says the revenue weight is 3500.
My ‘not much’ gave me an extra 1000kg overall payload and 200kg on the rear axle. I was happy with that.
I’d get to a weighbridge with everything you want to carry first to see how you stand (assuming you’re plated at 3500kg). It’s all well and good looking at the chassis plate, but it’s what you actually weigh on each axle that matters and will tell you how much, if any, you need to up plate by!Hi i am just new to the site and was wondering what the pros & cons are for increasing the payload. I have a fiat carrioca which if I am by myself weight is not an issue however I have just started to carry a very heavy ebike which may affect the weight of the van.
If it's just a paper excercise, then you probably won't gain much in overall payload. The permissible axle weights will remain the same. All it allows you to do, is shift the load around to optimise the loads on each axle.
Are you sure about that? VED for PHG motorhome is LESS than for PLG. When you uprate from below 3.5t to above 3.5t you do not pay anymore, they are supposed to give you a refund of VED.What they do not make clear when submitting Paperwork for up plating is that a cheque for 6 or 12 months ved at the new weight ie PHG must be included with the paperwork being submitted if not the application does not go ahead and a replacement V5 at the old rate is sent back to you (this is the mistake I made) Seemingly they are not obliged to notify you of this when submitting as happened to me and I suspect the submission is recorded electronically and all paperwork is shredded hence no paper trail when I queried it. If the OP wants to go this route on his own pm me and I will provide instructions.
Don't think that is correct as you have already paid more than the new VED. Didn't send a cheque with mine, they just refunded the difference but it did take them 4 months.What they do not make clear when submitting Paperwork for up plating is that a cheque for 6 or 12 months ved at the new weight ie PHG must be included with the paperwork being submitted if not the application does not go ahead and a replacement V5 at the old rate is sent back to you
